Smoking/Tinting Tail Lights
Old May 12, 2008 | 03:18 PM
  #41
falkore24's Avatar
Default RE: Smoking/Tinting Tail Lights
LED's are more intense than bulbs, so they create a brighter point source of light. The total light output is less than the bulb though.
Old May 12, 2008 | 06:23 PM
  #42
donpisto's Avatar
Ah, gotcha. Thanks for the clarification. I bet I'm not the only one who thought LED's were brighter
Old May 12, 2008 | 08:31 PM
  #43
finch13's Avatar
ORIGINAL: donpisto
ORIGINAL: finch13
Sylvania makes Silverstar and Silverstar ULTRA bulbs that are a bit whiter and brighter than regular halogens. DDMTuning also makes a relatively cheap ($150) HID kit in a range of temperatures.
Thanks for the info. If I hadn't bought the headlights I have I probably would go with the HID kit. Just gotta get me some of the bulbs you mentioned tho.
You can still get HIDs, they have numerous bulb sizes. falkore had HIDs in his stock housing, they were legit.
Old May 12, 2008 | 08:32 PM
  #44
finch13's Avatar
ORIGINAL: falkore24
Just a heads up ..... LED's in the reverse lights look cool, but don't put out as much light ...... might want to consider sticking with bulbs there.
Even those 30 LED bulbs? If you set up an array in there it could potentially be brighter than filament.
Old May 13, 2008 | 09:36 AM
  #45
falkore24's Avatar
ORIGINAL: finch13
I'm just going by the things that I've read and pictures that I've seen. I think the swap on tC's is usually a 5 LED cluster, but I may be wrong. A massive array like you mentioned may be brighter, but will it fit the housing?
I thought that LED's would be brighter too and had done this research because I had planned on doing the swap as well. I think I'm going to see if I can find ceramic sockets so I can run 50W bulbs ..... I have to back into my parking spot at night and it's very dark behind me.
Old May 13, 2008 | 10:30 AM
  #46
donpisto's Avatar
ORIGINAL: finch13
ORIGINAL: donpisto
ORIGINAL: finch13
Not sure how to do HID's for the headlights I have. This thread mentions my situation. https://www.hondaaccordforum.com/HID..._122854/tm.htm
Old May 13, 2008 | 11:54 AM
  #47
falkore24's Avatar
ORIGINAL: finch13
I had HID's in TYC housings. It was an H1 conversion.
Old May 13, 2008 | 12:41 PM
  #48
donpisto's Avatar
Hmm, I gotta see what the ones I have use. They aren't TYC as far as I know (otherwise they would have been more expensive).
HigherThanMars
Aug 15, 2013 12:56 AM
myfirstisanaccord
Apr 24, 2011 08:25 PM
o3transaccorder
Canada, Over Seas & Elsewhere
Jun 19, 2010 07:37 PM
Bilal Khan
Mar 5, 2008 08:57 AM
nighthwkblkaccord07
Jul 13, 2007 12:16 PM
