03 Factory Speaker Replacement
Old Jun 22, 2006 | 09:15 PM
  #21
03Sleeper's Avatar
Default RE: 03 Factory Speaker Replacement
HolyMother...look at the Accord....
See...this is what I want to avoid, I want trunk space.
[IMG]local://upfiles/4351/77291D29912A48478C2551EBD1BFE029.jpg[/IMG]
Old Jun 22, 2006 | 10:10 PM
  #22
marbro's Avatar
what are you talking about, theres plenty of trunk space there ^_-
Old Jun 23, 2006 | 12:00 AM
  #23
03Sleeper's Avatar
But I dont wanna put stuff, such as groceries, instruments, etc., on top of the stuff...it'll either damage the goods or the speaker, wouldn't it?
Old Jun 23, 2006 | 10:42 AM
  #24
marbro's Avatar
pretty much, you have to keep in mind, thats a show car. Anyone who puts lcd's and tweeters/midranges in the trunk with no plans of having it be a show car has waaaay too much money. And there is no spare in that trunk, if you were to put subs you would have 1 amp powering 1 or 2 subs
Old Jun 23, 2006 | 04:49 PM
  #25
03Sleeper's Avatar
True. One powered sub is enough for me...I mean this is my car and its a daily driver.
Old Jun 24, 2006 | 05:08 PM
  #26
03Sleeper's Avatar
EDIT - Visonik V693 - Visonik 6"x9" 4 Way 240 Watt Speaker (See Pic) [On Order]
I think I just found the best deal....ever.
[IMG]local://upfiles/4351/F1013CBFFC5F41D3832453EF7637625D.jpg[/IMG]
Features:
* Amp & Ported Dual Subwoofer System Combo
* DUB4001 Amplifier:
o RMS Power Handling: 400 watts x 1 Chan.
o Brushed Aluminum Chassis
o Top Mount Controls with Blue Illumination
o Cooling Fan
o Chrome Dub Fan Grille
o Doublesided Glass Epoxy Circuit Board
o PWM MOSFET Power Supply
o THD: 0.02%
o Signal-to-Noise Ratio: 100 dB
o Frequency Response: 10 Hz - 40 kHz
o Variable Crossover: High-Pass (75 Hz - 750 kHz), Low-Pass (50 - 150 Hz)
o Selectable Bass EQ
o 4-Way Protection Circuitry: Thermal, Short Circuit, DC Offset, and Overload
* 12" Subwoofers:
o Oversized 45 oz. Double Stacked Strontium Magnet
o RMS Power Handling: 300 watts
o Frequency Response: 24 Hz - 1 kHz
o Efficiency: 87 dB
o 1-1/2" Foam Surround
o No-Press Pulp Cone
o 1-1/2" 4-Layer ASV Voice Coil
* Enclosure:
o Medium Density Fiberboard Construction
o Chrome Venturi Ports
o Gold Binding Post Terminals
o Durable Ultra Black Carpeting
[IMG]local://upfiles/4351/94640F49ABF549BE818CF4B59B9156C3.jpg[/IMG]
Old Jun 25, 2006 | 01:44 AM
  #27
marbro's Avatar
what is your plan exactly? doing amp powered 6x9's? or is the amp ment for a sub?
Old Jun 25, 2006 | 02:24 AM
  #28
03Sleeper's Avatar
The amp is meant for the sub. I guess I sorta new better speakers to complete the sound. I mean stock speakers won't sound as good with the sub, wouldn't it?
And I'm scared that I'll blow out the stock speakers with the new sub and amp system...since the amp is a single channel, I can't wire them both.
Old Jun 25, 2006 | 04:38 AM
  #29
marbro's Avatar
you could, but you would probably burn out the amp depending on the config, but stock speakers usually only go up to 40 watts max, give or take a few watts. Sticking with the sub on the amp is the best thing to do. As for anything else change the deck and you most likely will get the power you need for any after market speakers, a deticated amp is always better but some speakers run great off the deck in general
Old Jun 28, 2006 | 10:17 AM
  #30
03Sleeper's Avatar
So you're saying, stick to the stock speakers and return the Visonik 6x9s?
I can't hook up the speakers to the sub anyways, it's a 1 channel.
