2002 Accrod Sedan Odometer Bulb
Old Nov 19, 2010 | 09:37 PM
cardude720's Avatar
Default 2002 Accrod Sedan Odometer Bulb
My sister's '02 accord's odometer bulb is burnt out. How hard is it to replace/get to? I know on some cars its very easy and some can be a real pain.
I just did mine and it took less then 15 minutes:
http://forum.miata.net/vb/showthread.php?t=399092
Thanks,
Mark
Old Nov 23, 2010 | 12:40 PM
keep_hope_alive's Avatar
it's easy. in front of the instrument cluster is a trim piece with two screws on top (use a stubby phillips). once that is off, there are like 4-6 screws or 10mm bolts holding the instrument cluster in place. remove those then work the instrument cluster out.
Be patient as you'll have to unplug the three wire harnesses before it comes out completely.
the bulbs unscrew with a quarter turn. you can buy them at a local dealership or at hondapartsdeals dot com.
Old Nov 28, 2010 | 02:53 PM
cardude720's Avatar
great, thanks!
lecola
Oct 12, 2012 03:28 PM
Curious3470
Sep 4, 2009 11:48 AM
dtikili
Mar 6, 2009 02:17 AM
tuthill
Aug 20, 2007 01:27 PM
nil
Oct 24, 2006 10:37 PM
