2007 SE V6 - aftermarket stereo options
Old Jan 28, 2012 | 11:07 AM
keep_hope_alive's Avatar
You simply add a LOC on the factory speaker outputs and feed that signal into the aftermarket HU through an aux input.
Old Jan 28, 2012 | 04:46 PM
Jes1774's Avatar
That sounds simple. I guess I'd just go with a 2 channel loc and set the factory deck fade all the way to the front or back.
After going back and forth on wether to use a processor And adding ipod controls on the oem deck or using an aftermarket deck, I think I'll go the aftermarket route for sq. is that the general consensus for sq?
Old Jan 28, 2012 | 11:17 PM
neophyte's Avatar
consensus on is it better or are you asking for brand recommendation?
Old Jan 31, 2012 | 09:08 PM
yea, aftermarket is best for SQ. then LOC into the AUX to still use the factory deck. just make sure to keep power to the factory.
i run new power wires for aftermarket and new speaker wires as well. i try to not use any factory wiring. i'll tap an ignition wire to run a relay coil for switched power for the HU.
Old Jun 5, 2012 | 10:19 PM
MassAppeal16's Avatar
marked for later
Old Jan 3, 2013 | 06:25 PM
Raté's Avatar
Default Mounting in a second stereo
Originally Posted by neophyte
all I know of is that metra one you have posted, and I dont think you will find a nicer one. you can however mount your deck in the lower cubby and keep your factory radio in the car.
I have a 2007 Accord with the 6-disc changer. Do you know where i can find detailed instructions on how to wire in a second radio and still use the steering wheel controls for that second radio? I don't care about using my factory radio except for temperature control.
Thanks!
Old Jan 7, 2013 | 10:51 PM
  #17
the PAC-Audio SWI-X is a universal interface for steering wheel controls on select aftermarket head units. the wires needed to intercept are described below as "radio remote switch". just follow the instructions on the SWI-X.
Metra-Online sells the mounting kit and wiring harness required - and they provide how-to instructions.
Metra Part # 99-7862 | Honda Accord Dash kit | Metra Online
http://www.metraonline.com/files/pro...NST99-7862.pdf
cheers.
Old Jan 9, 2013 | 11:22 AM
  #18
Raté's Avatar
Excellent, thanks so much for the advice! I'll look into this!
imageicb
Apr 28, 2008 08:19 AM
Nekozuki
Mar 3, 2008 11:13 PM
billeethakid
Jun 11, 2007 07:26 PM
jprez1980
Apr 3, 2007 02:57 PM
ak47
Feb 20, 2006 11:41 PM
