97 Accord Firewall
Old Apr 13, 2012 | 07:24 AM
crispin's Avatar
Mr Ricer,
I went out to look at the car this morning to see why you were having a difficult time as I remember it being so easy.
Well I forgot to mention a step which makes it much easier.
Disconnect the battery and take out the 2 - 10mm bolts holding the under hood fuse box. The fuse box also has 1 clip holding it down, gently pry up on it and it will lift up a few inches exposing the grommet that you will push the wires through.
Here are a couple of pictures, you can see the yellow wires and red wires are going through the grommet into the car.
Old Apr 13, 2012 | 08:38 AM
RobinsonRicer's Avatar
thanks, thats the spot i was looking at. ill lift the fuse box up. as for the other side, there are covers in the way. if i get far enough under there should i be able to see it or do i have to move anything?
Old Apr 13, 2012 | 08:49 AM
crispin's Avatar
just pull the top of the carpet down a bit and you will see your screwdriver / coat hanger sticking through.
Old Apr 13, 2012 | 06:43 PM
So I stuck a screw driver through that, the issue is the other side. There is a plastic cover on the bottom blocking everything. The entire firewall where the screwdriver would be is inaccessible and I can't remove anything too easily.
Old Mar 2, 2014 | 01:47 AM
ALDJ1's Avatar
Originally Posted by crispin
I have a 97 Accord 5 speed as well.
Takes like 1 min to run a wire through that groment, removing the ECU or glovebox is not required.
I know I am a bit late to the forums, but I am new. Is this grommet available on the 1994 Honda Accord LX too, since the body style is the same?
fjpthree
Apr 4, 2013 10:28 PM
jsmackle
Nov 15, 2012 08:45 PM
03EXLJ
Apr 23, 2011 09:59 PM
pham9006
Sep 8, 2007 02:10 PM
sibaudio
Mar 7, 2006 01:19 AM
