98 Accord radio antenna
Old May 12, 2010 | 07:56 AM
elmo's Avatar
Default 98 Accord radio antenna
I am trying to remove the factory radio from the center console to replace the antenna with an FM adapter for my XM radio. Is there an easy way to pull the radio without removing the whole dash?
Old May 12, 2010 | 08:45 AM
It's not so much pulling the whole dash; more like pulling the center console. Still, that's a lot of stuff before you get to the radio. I bet you'll get better answers in the A/V Elect. section so I'll move this over there.
Old May 12, 2010 | 12:42 PM
keep_hope_alive's Avatar
pulling the factory radio takes me about 3 minutes.
here are the steps (from memory for my 2001)
1. remove clock/hazard from between the two middle vents. this just pulls out. disconnect the harness(es).
2. remove one phillips screw behind that.
3. remove two phillips screws on the bottom of the black trim plastic radio trim piece, just in front and above the shifter. you'll need a stubby phillips, and may need to bend down to see them.
4. remove the black plastic trim that houses the A/C controls and vents. the radio stays put. Disconnect the A/C control harnesses.
5. remove the four 10mm radio bolts. slide out radio.
BABroome
Dec 2, 2014 04:11 PM
kevin6655
Apr 14, 2013 11:19 AM
bustedhonda
Mar 12, 2009 02:23 PM
odinsvalk
Sep 4, 2007 07:06 PM
mumbly2003
Jan 5, 2007 09:12 PM
