Adding Amp to 08' accord
Old May 28, 2008 | 02:47 PM
raskacielo
Default Adding Amp to 08' accord
I try adding an amp bu putting in a hi-lo converter but a get a weird noise comming out of the speakers.
kind of like a real loud vibration, even when the car is off.
can someone help?
Old May 28, 2008 | 06:50 PM
finch13's Avatar
Default RE: Adding Amp to 08' accord
You probably have the power and signal wires running too close and you're getting noise in the lines. Try a ground loop isolator from Best Buy or other electronics store with car audio, they'll know exactly what you're talking about.
Old May 29, 2008 | 10:37 PM
raskacielo
thanks, tried but didnt work.
i called an installation place n the guy told me that hondas have microphones in the front n back that help control the volume output of the speakers n that i should disconnect them.
ill try as soon as possible n will let ya know if it work.
Old May 30, 2008 | 08:44 PM
MacLeod's Avatar
Gawdamighty! Microphones?!?!
I will never understand the auto industry's seemingly deliberate campaign against the car audio aftermarket.
Every year they make it harder and harder and harder to upgrade your audio with some quality aftermarket gear.
The punchline is that they stick in all these stupid things that are very difficult if not impossible to bypass - and yet THEY STILL SOUND LIKE HAMMERED CRAP!
I dont get it.
Old Jun 1, 2008 | 11:17 PM
moneytimetycoon's Avatar
Always double and triple check all your connections
Old Jun 4, 2008 | 02:03 PM
kumazam's Avatar
do you have the blue tooth option in your car?
if so, id think thats what the microphones are for
Old Jun 4, 2008 | 03:37 PM
slammed97's Avatar
I'm betting the microphones could be for the auto volume leveling feature. Measures ambient noise and adjusts the volume accordingly (lame pun intended). You could try to disable the auto volume adjustment to see if that makes a difference.
Also, does your line level converter have a ground connection? If so, make sure it is a quality ground point.
If that doesn't work just rip it all out, throw in a full JL system with Evolution ZR component sets, W7 subs, and HD amps and forget about it.[sm=signs003.gif]
Old Jun 4, 2008 | 03:56 PM
kumazam's Avatar
ORIGINAL: slammed97
I'm betting the microphones could be for the auto volume leveling feature. Measures ambient noise and adjusts the volume accordingly (lame pun intended)...
i think thats based on the cars' speed not ambient noise?
Old Jun 4, 2008 | 04:40 PM
falkore24's Avatar
Default RE: Adding Amp to 08’ accord
try another set of RCA’s if you have some .... I’ve seen bad humming from bad RCA’s as well as loose RCA connections ..... also, make sure that the LOC gain isn’t too high if it has a gain control
jcarver6
Jul 15, 2013 01:57 PM
BlackKnight
Oct 4, 2012 06:36 PM
drumdoctor
Jan 16, 2012 09:53 AM
KAOSINKS
Dec 9, 2011 05:01 PM
soulbrother2002
Feb 15, 2006 12:46 AM
