Adding a powered subwoofer and Alpine KTP-445U Power Pack
Old Jun 20, 2013 | 10:01 AM
reklawj's Avatar
Default Adding a powered subwoofer and Alpine KTP-445U Power Pack
Will I still need to disable ANC if I am only adding a powered sub such as the Kicker - Hideaway 8" Subwoofer
I also wanted to add the Alpine power pack wanted to your thoughts on whether or not that would create problems as well.
Old Jun 20, 2013 | 09:55 PM
neophyte's Avatar
the power pack should not cause problems. if you get feedback then you will need to disable the mics. if not then you wont need too.
Old Jun 22, 2013 | 10:56 PM
keep_hope_alive's Avatar
because you are changing the amplification of the speakers, you will need to disable ANC.
Old Jun 22, 2013 | 11:55 PM
neophyte's Avatar
here is a question that this thread makes me think of. KHA: would you even be able to add the power pack in or would you have to bypass the factory amps. (i am thinking the newer ones have external amps).
Chach769
Mar 24, 2013 01:45 PM
iluvsnapple
Aug 19, 2011 06:51 AM
felpz420
Jun 27, 2011 09:41 PM
dalilama
Nov 7, 2009 08:08 PM
64tinc
Jun 22, 2009 11:48 AM
