amp/audio issues
Old Apr 10, 2011 | 04:49 PM
kendra63's Avatar
Default amp/audio issues
Sooo my last stereo...stopped working, no sound using the radio/cd player...or even beeping when i leave the lights on when i turn my car off and get out....
i just bought a new stereo and installed the wiring harness and everything, thinking it was just my last crappy stereo
...but the same thing happens no sound...no radio, cd, silence! its driving me crazy...
anyone else have this problem? or suggestions for this problem! anything would be appreciated! thank you!
Old Apr 10, 2011 | 05:24 PM
tkrotchko's Avatar
I'm sure you already checked the obvious (fuses), check there's power in the harness, etc.
Old Apr 10, 2011 | 07:17 PM
kendra63's Avatar
yeah i just re-checked all the fuses, and in the process of finding the stock amp so i can check if that even has any power...i will check the harness at work when i get the wire tester...if there isn't power in the car harness...would i have to re-wire everything?
Old Apr 10, 2011 | 08:34 PM
tkrotchko's Avatar
Not necessarily. You'll have to trace the dash/radio harness (I'm assuming you've just plugged into the existing harness and not screwed around and wired around it) to where it plugs into the main harness.
As a test, you could bypass the harness and take a wire directly from the fuse box. I would not wire around the fuse box (i.e. take a hot directly from the battery). Only bad things will happen if you do that.
Old Apr 10, 2011 | 09:26 PM
keep_hope_alive's Avatar
Use the DMM to verify both ignition and constant voltage first. That begins your trace.
Old Apr 12, 2011 | 08:02 AM
kendra63's Avatar
so i tested the wires and my back rear left speaker wire is totally dead...any suggestions on how i could rig that up to work?
Old Apr 12, 2011 | 05:15 PM
Replace the wire?
Old Apr 13, 2011 | 03:54 AM
tkrotchko's Avatar
When you say you tested it, you mean that you tested continuity between the wire at the head unit and the speaker, and there is a break in the wire some place?
If yes, then you have to replace that section of wire.
How exactly did you test it?
lakario
Aug 10, 2012 03:29 PM
drumdoctor
Jan 16, 2012 09:53 AM
hiphophead
Jun 30, 2011 07:59 AM
Nadoo
Jan 7, 2008 12:19 AM
tru_44
Jul 16, 2007 10:23 PM
