amp and subs dimming lights
Old Jul 28, 2007 | 08:38 PM
steviebix's Avatar
Default amp and subs dimming lights
okay, so on my car with a 300 watt Pioneer amp, 2 kicker 10's, and kenwood deck, all my lights, including heads and tails, neons and gauges, all dim when the subs hit. like their pulsing to the music. but i definetly dont want it. seems like my car is being overloaded with power and cant handle it all. what exactly should i do? links? names? anything? thanks.
[align=left] [/align]
Old Jul 28, 2007 | 09:59 PM
smaglik's Avatar
Default RE: amp and subs dimming lights
cheapest first...
first, improve your ground points.
second add a capacitor
3rd, yellow-top (high performance) battery
4th, high output alternator.
Old Jul 28, 2007 | 11:30 PM
tru_44's Avatar
^ yeah what he said, lol also big 3,and batt dosen't have to be yellow top but a high end brand is reccomended,and to be real cheap and spend nothingride with your ac off
Old Jul 29, 2007 | 11:36 AM
steviebix's Avatar
can anyone recommend a brand of capacitor or a place where i can get one? where does it go exactly? on the amp? on the amp wiring?
Old Jul 29, 2007 | 01:10 PM
tru_44's Avatar
ebay has cheap caps, you run power wire from batt to cap(+)and from that to amp(+) ground cap and amp to metal, also a new cap should come with instructions
Old Jul 29, 2007 | 01:13 PM
tru_44's Avatar
Old Jul 30, 2007 | 11:13 AM
Hebrew Hammer
the big 3 should be first along with a better battery...caps are only good for helping the cars electrical system deal with the harsh loads of a stereo system but do little if anything at all for the actual system...your alternator should be suffice for now...
Old Aug 24, 2007 | 09:45 AM
Wolf
Wow, your lights are dimming with only 300 watts of power? At one point in time I had a kicker L7 15" subwoofer in my car running on a kicker zx 1000.1 amp (1000 watts power) My lights dimmed then. I had to replace the amp and bought an mtx thunder series 600 watt amp and it doesnt dim at all, also I now have an alpine amp on my highs and still no dimming...I didnt know that could happen with such low wattage.
Old Sep 5, 2007 | 11:29 AM
bssmagik83's Avatar
Almost A Senior Member
I also have a 1000 watt amp and a 15" L7, I have no dimming...make sure you have a good ground for the amp...And I would also recommend doing the big 3 grounding..upgrade the battery if that stuff doesnt help....What else are you runningoff your battery?
Old Sep 5, 2007 | 12:13 PM
falkore24's Avatar
I agree with grounding and a cap. If you don't have any trouble starting your car, there's no need for an upgraded battery. Also, the cap does not have to go between the amp and battery. It just needs to be hooked up to the main lead that powers your amp. It can be a branch on a distribution block. The cap will also help cold starts. With the power that you are running better grounding should take care of the problem, but a capacitor will buffer the electrical system from voltage spikes and valleys caused by the subs.
Bottom line, do #1 and see if you need to go from there. #2 is always a good idea and will also give you better bass suspension. #'s 3 & 4 should not be necessary with this power demand.
jon.hand
Jun 15, 2011 08:34 AM
Nadoo
Jan 7, 2008 12:19 AM
HondagalGA
Nov 20, 2006 10:55 AM
Gebo
Oct 16, 2006 08:21 AM
DVan8504
Feb 2, 2006 10:18 AM
