audio overhaul. but how to remove the existing equipment???
Old Nov 16, 2006 | 06:55 PM
ivrex's Avatar
Default audio overhaul. but how to remove the existing equipment???
ok well yesterday i bought a 95 4dr EX. it came with an aftermarket HU but stock speakers. the speakers are pretty much shot, the surround has seperated from the cone.
anyways, i need to know how to get the headunit out so i can put mine in by removing the center dash, also how to access both the front and rear speakers, i tried to pry the cloth grills off but they were resistant so i wasnt sure if that was how they came off and did not want to break anything so here i turn to you all. also if i am correct, i understand my car has 6.5" midbass and tweets in the dash but cannot find the tweets, where are they located and how access them?
i know this is alot of info i am asking for and it is most likely floating around here but havent found it. anyone who can help i would greatly appreciate.
many thnx
Old Nov 16, 2006 | 07:43 PM
sir_nasty's Avatar
Default RE: audio overhaul. but how to remove the existing equipment???
Center console removal:
http://www.installdr.com/InstallDocs/Honda/Accord.html
The side door speakers just grab the cloth grills around the speakers in the door and squeeze together a bit and pull and they should pop off.... the tweets in the dash can be seen if you look down the A pillar to where it meets the dash/windsheild tucked away in the corner and they just pop up and twist a little bit to remove them
Old Nov 16, 2006 | 11:49 PM
ivrex's Avatar
wow its a bit more intricate than ud think looking at the consol, np tho, thanks
Old Nov 17, 2006 | 12:09 AM
19Accord97
Once you do it one time it becomes really easy. Good luck!
Old Nov 20, 2006 | 12:12 AM
ivrex's Avatar
anyone know the mounting depth of the door speakers. id like to replace them with any xtra work
Old Nov 21, 2006 | 11:34 AM
poser_pilot6
Try going to Crutchfield's website, they will be able to tell you what mounting depth you need for your front speakers.
hiphophead
Jun 30, 2011 07:59 AM
cherychery
Dec 21, 2009 06:55 PM
itzztrick
Dec 8, 2006 04:01 PM
msmi11
Nov 6, 2006 11:09 PM
