CD Player Condensation
Old May 15, 2012 | 07:48 AM
rayzrbaks's Avatar
Default CD Player Condensation
I've got a 2003 Accord LX. Just about everytime I run the A/C and listen to a CD in the single disc player, condensation builds up on the CD and the CD stops playing. Anyone else run in to this problem? And if so, any idea on how to correct it?
Old May 15, 2012 | 06:30 PM
neophyte's Avatar
my car stays really cool in that area because of the way that the events hook up. are you running a stock stereo or an aftermarket?
Old May 16, 2012 | 09:05 AM
rayzrbaks's Avatar
I'm running a stock stereo.
Old May 16, 2012 | 12:41 PM
keep_hope_alive's Avatar
i can certainly see that happening. can't correct it without reducing the interior car temp slowly, or using good sun visors and parking in the shade to reduce interior car temp.
make sure you don't have a vent leak that is causing cold air to blow directly down on the head unit inside the dash.
Old May 16, 2012 | 02:59 PM
rayzrbaks's Avatar
Going to put some foam insulation around the two vents that sit above the head unit. This should keep any cold air from leaking in a causing condensation. I hope, anyway.
Old Sep 4, 2015 | 03:53 PM
knightEknight's Avatar
How did this work out for you? I have the same car and same issue. Thanks!
Old Sep 4, 2015 | 08:45 PM
Prospector's Avatar
Is the AC draining properly?
Old Sep 6, 2015 | 03:16 PM
In my case yes, it is definitely condensation and not a drainage issue.
Old Sep 20, 2015 | 03:20 PM
Here is a good working resolution that won't cost you a bundle:
Old Sep 21, 2015 | 12:52 PM
thanks for following up.
i think applying closed cell foam sheets to the bottom of the ducts is a viable solution.
treating the source (air leak) is preferable.
Will14
Jan 8, 2009 07:43 AM
Robcie
Jul 31, 2007 12:22 PM
91boz
Jun 22, 2007 06:16 PM
acs4ny
Dec 19, 2006 03:00 PM
BostonPuppyDawg
Sep 1, 2006 01:52 AM
