connecting subs to amp
Old Aug 22, 2013 | 06:23 PM
iskate604's Avatar
Default connecting subs to amp
I have 4 channel e11 rockford fosgate amp with 2 10" mtx tc510 in thunder box got for free in good condition I don't know much about subwoofers but would it be best to bridge or connect to one channel?
Old Aug 23, 2013 | 08:55 AM
neophyte's Avatar
are you only running the subs with the amp or are you running speakers as well?
Old Aug 24, 2013 | 06:49 AM
keep_hope_alive's Avatar
assuming they are each 4 ohm single coil
you can bridge one sub to each channel pair
sub 1 to ch 1&2
sub 2 to ch 3&4
use a DMM to measure VAC on the amp outputs to adjust gain to be equal on both channels (and you can calculate the voltage you would get at rated power). for rated power output, call Rockford Fosgate and give them the various model/serial numbers.
monguin61
Feb 9, 2013 02:42 PM
Nadoo
Jan 7, 2008 12:19 AM
steviebix
Sep 5, 2007 12:13 PM
indyhondashine
Jul 7, 2007 03:05 PM
bpo145
May 15, 2007 10:28 PM
