Done with my tunes
I'm thinking about going with a setup similar to RTexasF's setup. I have the sub already, and just got a MTX 404 amp off craigslist to power the speakers.
I'm thinking about going with the clean sweep unit, but I have a question. Where did you mount your clean sweep/amp? That pic of your trunk (very clean btw), is that your amp? I'm just trying to get an idea of how I should wire the speakers. I assume all of the stock speaker wires are going to the head unit. Should I plan on running all new wires from the trunk to the speakers?
I have done basic head unit replacements on my cars before, and even installed a sub or two, but never anything this complex.
Also, does the stock head unit have something that can be used as a remote lead (for remote power on for amps and such)? What did you use?
Thanks for any information you can provide on your setup. Looks like you did a very good job.
I ran my remote from a blank fuse holder under the steering column...the only thing is you have to find one that stays on while the car is running...use a little teo prong spade connector and it fits right in there just like a fuse would..
ORIGINAL: gamemaster000
This was all done piecemeal over a period of three years as I could afford it. Sure, I'd like more low end but a usable trunk was my toppriority so a quickly removable self contained sub was the best answer. In other words....compromise.
Drpepper
Nov 7, 2013 11:58 AM
DALAZ_68
Oct 3, 2006 03:19 PM
