Fog light wires thru the firewall
Old Dec 17, 2006 | 10:57 PM
huzzsaba's Avatar
Default Fog light wires thru the firewall
i need to install the switch for the aftermarket fog light i bought. I have to run the wires thru the engine bay into the car. Where is the best spot to get it thru? I have a 94 accord. I found a spot above the fuse box inside the car where there is a rubber boot kind of thing with a whole bunch of wires coming thru from the engine bay. should i put it thru there? And do i just pull the boot off and press it back in?
Thanks
Old Dec 17, 2006 | 11:31 PM
t00fatt's Avatar
Default RE: Fog light wires thru the firewall
Yeah thats the best gasket to go through. The best way is to cut a X in it and fish it through with a metal hanger. You could pop the gasket off the edge and pass it through there, but then you lose the seal.
Old Dec 18, 2006 | 01:13 AM
huzzsaba's Avatar
hey! thanks for the reply. I just took the whole gasket off and passed it thru. it seal up pretty good tho. Thanks!
fjpthree
Apr 4, 2013 10:28 PM
zeroice
Nov 17, 2009 08:45 AM
maddentp7
Oct 17, 2007 11:22 AM
Calevra18
Sep 16, 2007 10:45 PM
Aug 9, 2006 12:34 PM
