front speaker size
Old Apr 17, 2007 | 09:22 PM
f22exr's Avatar
Default front speaker size
Yes I know I've posted about this but I need someone to tell what size the front speakers are in a 1990 ex-r sedan cause ive checked a few sites..such as crutchfield..and some honda one and the sizes are both different...how could this be? :S its starting to annoy me..anyways the cruchfield site says 4" and the honda says 5-5.5" can someone please answer this for me it would be appreciated, thanks
Old Apr 18, 2007 | 01:13 AM
MacLeod's Avatar
Default RE: front speaker size
Dont know about the 90 Accords but the newer ones have 6.5's in them but good luck getting an aftermarket 6.5 in there without some cutting.
Id say youd need a 5.25 for a good fit.
Best thing to do would be either take the door panel off and see for yourself or run down to your local stereo shop and talk with them. Theyll be able to tell you more and lay out your options better.
Old Apr 22, 2007 | 11:30 AM
2kflhr's Avatar
This is the easiest and surest way that I know of.
http://www.crutchfield.com/S-wC8Uy5h.../autoinfo.asp?
Old Jun 13, 2007 | 07:09 PM
karlneff
The only SURE way to determine what sizefront speakers you have is to pull off the inner door panels and look - I also ran into the same problem with my '91 LX sedan - it turned out the front speakers were 5 1/4 inch - try to find some speakers with shallow mounting-depth, or you may have to cut out part of the factory speaker baffle to get the magnets to fit (but be careful not to install speakers with too large of magnets, as they might interfere with the windows rolling down all the way!).
2010HondaAccordLiquidMetal
Apr 22, 2014 11:41 AM
freedom357
Apr 2, 2012 03:04 PM
f22exr
Jun 30, 2007 10:47 PM
2002haccord
Nov 3, 2006 05:25 PM
bluebeast11
Feb 5, 2006 10:22 PM
