guage help
Old May 23, 2011 | 06:44 PM
widowmaker's Avatar
Default guage help
i have a 2000 accord lx and i just replaced the cluster lights to led. now the lights are changed and work but the speedometer or the tach and temp guage in the cluster work nor the digital odometer or pwr windows. i checked the fuses didnt see nothing blown and checked the plugs to make sure there pluged in and they were anyone have any help
Old May 23, 2011 | 10:01 PM
neophyte's Avatar
test the fuses. just because they dont look blown doesnt mean they arent.
Old May 24, 2011 | 09:35 AM
widowmaker's Avatar
what ones should i check that run the windows and also the the guage cluser
Old May 24, 2011 | 01:03 PM
keep_hope_alive's Avatar
Use a DMM to measure voltage, only way to trace your issue. You didn't get one or more of the harnesses on the cluster plugged in.
Did you disconnect battery negative? That should have been done b4 you did this. Do that now to reset the car.
Power windows are separate from the gauge, but are tied to ignition and the door switch in some cars. You shouldn't have affected that fuse though. Check each fuse by measuring voltage on both metal tabs on the top of the fuse. Voltage on one side but not the other indictes a blown fuse,
Old May 24, 2011 | 11:21 PM
widowmaker's Avatar
Default haha
no i didnt disconnect the negative but i took the cluster out and replaced a blown light now nothing works (tach,speed,fuel temp and windows) but the lights on the cluster work checked the fuses again yet they are still fine
Old May 25, 2011 | 04:26 PM
Disconnect negative and open drivers door. Wait 5 minutes. Reconnect negative. You may need to reset the computer.
Old May 25, 2011 | 06:31 PM
widowmaker's Avatar
how do u reset the comp i ran outta gas today cause my fuel guage isnt working
Old May 25, 2011 | 07:09 PM
this is how you reset the computer. have you done this yet? i suspect that it's either this or one of the wire harnesses on the back isn't fully seated.
note that you will need the 5-digit code to unlock the factory radio if it has a built-in security system (should say on the front).
i use my tripometer to keep track of gas mileage. i know how many miles i can get on a tank or partial tank.
Old May 25, 2011 | 07:39 PM
widowmaker's Avatar
Default yes
i have done that and nothing.i taken out the cluster again and pressed the three plugs back in the cluster and nothig still
Airdorn
May 9, 2013 08:51 AM
yosoymi787
Nov 1, 2012 09:11 AM
nickmg555
Apr 22, 2011 07:47 PM
dre2430
Apr 21, 2011 11:01 PM
Texas94Accord
Aug 26, 2006 10:32 PM
