H.O. Alternator replacement and big 3 wiring
Old Jun 4, 2012 | 11:15 PM
  #51
bellend's Avatar
I'm sorry to bump an old thread but I have 2 questions.
1. Do you recommend DC power alternators? I've heard bad things about Iraggi. Is 180 amp enough for a 1200 watt Mono block amp for my sub and another 600 watt amp for my components?
2. Where on earth can I get the high temperature webbed split loom like in your picture below? I've looked everywhere for it (Home Depot, Autozone, O Reilly, ebay.)
Old Jun 4, 2012 | 11:39 PM
  #52
crispin's Avatar
1) I do not recommend them as they are VERY VERY expensive.
I am running a 1,500 watt Fosgate Amp for my subs and a 400 watt MB Quart on my front stage. I bought a 180 amp alternator from this seller for $140 shipped to me. eBay My World - bnrparts You may have to message him as he does not list an alt for our car but will build one upon request.
I run a volt meter on my dash that gets its reading from my rear amp dist block. The alternator keeps up.
2) that is called tech flex - order it from this seller TECHFLEX
Any other questions feel free to ask me.
Old Jun 7, 2012 | 02:05 AM
  #53
bellend's Avatar
Thanks crispin! Very helpful answers.
Old Mar 20, 2013 | 08:38 AM
  #54
keep_hope_alive's Avatar
we purchased a new alternator for the 2005 Scion tC from Quality Power. Arrived quickly. Installed a 160A and quickly realized the Audison LRx5.1k was capable of pulling it down as well. The wonderful folks at Quality Power are letting us upgrade to the 240A.
the Optima battery is going to be replaced when we get the 240A alt. it floats at 12.2V and Optima won't honor their warranty (within 3 years). so we're going with a DieHard Platinum (made by Odyssey)
Old Apr 2, 2013 | 05:03 PM
  #55
eby.amber's Avatar
Default Help??
Hey there, new to the auto world and trying to fix up my car. I drive a 98' honda accord LX 2.3 automatic. I was having "alternator" problems and went to figure out the problem and had to replace the terminal end(it was so corroded that it actually snapped in two and the only reason the car was running was because it had the protective boot over it still,holding it together) , i saw that you used the same thing I did and reassured the connection with shrink wrap. what is the gauge for the original wire to buy the correct size shrink wrap? also, ive been having constant +battery terminal corrosion. the battery is about 2 1/2 years old, could it be the wire? battery? both? i've had the battery tested and they say its good,havent had car troubles due to the battery but i'm going on a long road trip and want it to be all set. any help would be great!! also, looking into doing some new stuff on my car,any suggestions? almost everything else is currently stock.
Old Apr 4, 2013 | 07:31 AM
  #56
the stock cable is about 6awg. size depends on if you will remove the stock ring terminal or not. i like it as close as possible. 3/8" should work.
battery terminal corrosion could be a small leak at the terminal. i assume you mean a build-up of white stuff? otherwise, copper will oxidize unless a battery terminal protectant is used.
what other "new stuff" are you interested in? audio/video? engine? aesthetics? see the those sections for ideas.
Old Jan 28, 2014 | 07:44 PM
  #57
autowiz's Avatar
it is not uncommon for my car to draw over 100amps at idle. what experience has taught me is that for most applications simply bolting a slightly smaller pulley on the alternator will bring its output potential up enough to compensate. or it will force it to spend more time at its max potential, anyways. for my Honda, i bought an alternator, took it to cliff out at startech here in south florida, and had him build it the best he could. he got it up to 170 or 180amps and put a smaller pulley on it so it could handle the insane load it sees regularly. it now uses a Toyota plug.
a good way to see if just a smaller pulley is all you need is to probe battery with dvom with all loads on and bring rpm up to 2000 or 2500k and see if charging voltage is good. and if so then the fix is simple and cheap. and can in some cases be done on the car. another good way is with a snap-on vantage pro with low amp probe clamped around the charge cable with the battery disconnected, or the battery cable with all loads on and the engine off. and if that number is smaller than the peak output of the oem alternator then a smaller pulley is all it needs. the car is wired from the factory to handle what the alternator can put out
and i don't think the eld is anything that needs to be played with. when you connect jumper cables the engine still bogs a little from the alternator full fielding trying to maintain voltage. the alternator will still work if you connect amp at battery. or, you could eliminate it altogether with some light wiring, like i did...
Old Jan 11, 2015 | 12:36 AM
  #58
it dawned on me i didn't show more detail on the grounding
factory strap
factory vs. replacement
location on the tranny sanded down
location on the body sanded down
replacement block to chassis ground AND battery to block
Old Jun 2, 2022 | 09:23 AM
  #59
MJones's Avatar
Attachment 18289
Hi there. My name is Melissa with Iraggi Alternator. I hate to hear you have heard bad things about us and would love an opportunity to answer any questions you may have to give you a better opinion of us...
DaIna-Kelela
Oct 11, 2012 08:15 AM
aking
Apr 4, 2011 11:19 AM
Ankit
Feb 7, 2010 02:43 PM
chico_dA_man
Mar 15, 2007 01:01 AM
trvlnut
Jul 27, 2006 02:57 AM
