How To: 2003 Accord Pathway
Old May 7, 2007 | 11:22 PM
cki3mn5tr
Default How To: 2003 Accord Pathway
So, I'm hooking up an amp and sub in my car, but I cant get the power wire from the battery to the amp. Does anyone know the pathway to take to link the wire from the battery to the amp.
Thanks.
Old May 8, 2007 | 09:34 PM
HuYnHness's Avatar
Default RE: How To: 2003 Accord Pathway
well i think you have to route the wire from your battery through your engine bay (along the side and back), find the hole in the firewall, route it through there into the dash, and under the plastic things on the floor near the door, then behind the rear seat into your trunk
sorry if that doesnt help you any what year is your car? maybe somebody can go check for you
Old May 9, 2007 | 03:01 AM
legionofone's Avatar
right in the middle of ur firewall there is a small rubber grommet... push it out with a screwdriver (its about the size of 4 guage wire) then run ur wire towards ur driver side... push it threw and u will get it out right under ur driver side console... now run it with a wire gromet that is right there (black corrigated plastic) and down around above all ur pedals then pull off ur fuse box cover and the interior panel... push the wire down behind the fuse box (remember not to hook it up to power yet...) pop up the side of of the plastic trim opposite from ur trunk lever... run it under and then pull off ur weather stripping and pop the B pillar trim off and run it under that... pull the trim off under the driver side rear and put the wire under that then run the wire between the seat and the C pillar foam up underneath ur rear seats fold down... and ur there... from there if ur looking for a good ground there is a REALY nice one right under the spare cover its a ground for the fuel pump... hope that helped...
nightowlll2010
Jun 1, 2013 12:55 PM
hoonhooon
Jan 7, 2008 06:47 PM
Jeff247
Mar 28, 2007 04:22 PM
gdr_11
Apr 7, 2005 08:58 PM
