Installing new head unit in 2006 with Navigation
Old Mar 31, 2016 | 08:20 PM
TravisS's Avatar
Default Installing new head unit in 2006 with Navigation
I recently installed a new Sony head unit under my existing Radio/Navigation system and I dont appear to be getting power to the new unit. The old one that is part of the navigation appears to work but there is no audio through the speakers. I used the metra wiring kit for this project. Has anyone else used this kit on an Accord with Navigation? Any tips?
Old Apr 1, 2016 | 01:18 AM
keep_hope_alive's Avatar
which wiring kit model number? how did the kit intersect the factory wiring? pics?
you will need to connect the blue/white wire on the Sony to the blue/white wire in the harness to turn on the factory amp.
Old Apr 1, 2016 | 07:48 AM
TravisS's Avatar
That is the Metro kit I used for the install.
I have not attached the two blue wires together. The one for the radio harness says it is for remote and the one on the Metra harness says it is for a power antenna.
I checked the fuse on the radio and that is intact as far as I can tell and I am going to check the fuses in the car at some point this weekend also.
Old Apr 2, 2016 | 07:20 PM
TravisS's Avatar
Just to let you know I figured out what the problem was. The metra wiring kit had either a bad wire on the constant 12 volt wire or it was cut somehow when they put it together. So I had to cut that bad piece out and put a new wire in it. Works fine now. Thanks for the help.
GodMachine
Jan 16, 2017 10:18 PM
krazyglue
Dec 12, 2014 06:50 PM
Duper
Jan 8, 2012 05:13 PM
djurchicprelude
Jan 11, 2007 02:12 AM
GodMachine
Jun 8, 2006 05:50 PM
