Installing subs in a 2006 Accord
Old Dec 18, 2017 | 01:01 AM
abestar's Avatar
Default Installing subs in a 2006 Accord
So i got this sub gifted to me
https://www.amazon.com/MTX-Terminator-TNE212D-200-Watt-Enclosure/dp/B001JECAM2/ref=sr_1_2?ie=UTF8&qid=1513579741&sr=8-2&keywords=mtx+sub https://www.amazon.com/MTX-Terminator-TNE212D-200-Watt-Enclosure/dp/B001JECAM2/ref=sr_1_2?ie=UTF8&qid=1513579741&sr=8-2&keywords=mtx+sub
Wondering what setup i should go with, currently have this in mind:
AMP:
https://www.amazon.com/gp/product/B004S4XNEO/ref=ox_sc_act_title_2?smid=A3SQ9YFE6CSCS0&psc=1 https://www.amazon.com/gp/product/B004S4XNEO/ref=ox_sc_act_title_2?smid=A3SQ9YFE6CSCS0&psc=1
Line out converter:
https://www.amazon.com/PAC-SNI-35-Variable-Line-Converter/dp/B001EAWS3W/ref=pd_bxgy_107_img_2?_encoding=UTF8&pd_rd_i=B001EAWS3W&pd_rd_r=7JRJMZXRDSE3XH02T7JV&pd_rd_w=eW3mz&pd_rd_wg=qYglw&psc=1&refRID=7JRJMZXRDSE3XH02T7JV https://www.amazon.com/PAC-SNI-35-Variable-Line-Converter/dp/B001EAWS3W/ref=pd_bxgy_107_img_2?_encoding=UTF8&pd_rd_i=B001EAWS3W&pd_rd_r=7JRJMZXRDSE3XH02T7JV&pd_rd_w=eW3mz&pd_rd_wg=qYglw&psc=1&refRID=7JRJMZXRDSE3XH02T7JV
Wires:
https://www.amazon.com/BOSS-Audio-Amplifier-Installation-Wiring/dp/B000FKP7TY/ref=pd_bxgy_107_img_3?_encoding=UTF8&pd_rd_i=B000FKP7TY&pd_rd_r=7JRJMZXRDSE3XH02T7JV&pd_rd_w=eW3mz&pd_rd_wg=qYglw&psc=1&refRID=7JRJMZXRDSE3XH02T7JV https://www.amazon.com/BOSS-Audio-Amplifier-Installation-Wiring/dp/B000FKP7TY/ref=pd_bxgy_107_img_3?_encoding=UTF8&pd_rd_i=B000FKP7TY&pd_rd_r=7JRJMZXRDSE3XH02T7JV&pd_rd_w=eW3mz&pd_rd_wg=qYglw&psc=1&refRID=7JRJMZXRDSE3XH02T7JV
Not familiar with subs or audio at all, i have the stock radio and am not looking to upgrade it for the subs
Old Dec 19, 2017 | 01:14 PM
keep_hope_alive's Avatar
Your plan will technically work, but there are much better options that are more likely to make you happy.
The LOC you linked doesn't have an auto turn-on remote output so you'll have sub noise problems with the current choice. I recommend one with a remote output to control the sub amp. I prefer this one:
Navone Engineering Inc. » N-RHL2 2 Channel, 50 Watt per channel, Line Output Converter
You amp selection is small and won't give you satisfactory output power. You're better off buying a used amp if your budget is that tight. Boss doesn't make good products in that price range. I've seen the Boss AR4000D make a clean 1kW at 1 ohm. Rockville has a few budget friendly amps that make usable power. We saw Boss Armor Series and Rockville amps used in a budget-friendly SPL challenge with some success (though none of us would run them daily). If you found a used amp from Rockford Fosgate, Alpine, JL Audio, Boston Acoustics, MTX, Crossfire, Memphis, Massive Audio, Kenwood, HiFonics, etc., you would get a better product for a good price, even if the amp was from the late 90's.
The wiring kit needs to be sized for the amp. 8awg is good to 60A of fusing, 4awg is good for 150A of fusing. Scosche, Stinger, and Streetwires all make decent amp kits.
Old Dec 21, 2017 | 07:34 AM
abestar's Avatar
Dang, so the amp i was gonna get is complete trash? haha.
Seems like theres a lot of good amp choices out there, im wondering what would be a decent amp, something thats not too hardcore, but something that is in between trash and top tier?
Old Dec 22, 2017 | 03:38 PM
Seeing as how you need a 2 ohm stable mono load, that limits your options to either monoblock amps (one channel) or a few 2 channel amps that can be bridged into 2 ohm (Boston Acoustics has some GT series). You only need a solid 500-600W RMS @ 2ohm rated amp (CEA compliant or similar). Ignore any max or peak ratings.
Alpine MRD-Mxxx or MRV-Mxxx series are good and widely available.
https://www.ebay.com/itm/Alpine-MRP-M500-1-Channel-Car-Amp/112695880454
Kicker ZX series
https://www.ebay.com/itm/KICKER-ZX300-1-Mono-Channel-Car-Amplifier/162806625650
Some Pioneer
https://www.ebay.com/itm/Pioneer-GM-D8400M-Class-D-Mono-Amplifier-USED/222757953812
Kenwood KAC
https://www.ebay.com/itm/Kenwood-KAC5001PS-Car-Amplifier/263391176524
Old Dec 22, 2017 | 03:43 PM
Rockford Fosgate has several mono options in their
BD series
Power series
https://www.ebay.com/itm/Rockford-Fo...e/282775569672
https://www.ebay.com/p/Rockford-Fosg...r-Amp/62460309
Old Dec 22, 2017 | 04:30 PM
Some comparisions of Boss so you get an idea of how they are rated (nowhere near printed)
AR4000D
AR1500M
dbeltran315
Jun 6, 2013 07:03 PM
Pilot Mobbin
Feb 10, 2013 08:07 AM
dbeltran315
Dec 19, 2012 11:29 PM
jamola10
Jan 14, 2010 12:05 PM
syclone521
Mar 30, 2007 09:36 PM
