Ipod adapter question
Old May 24, 2011 | 03:29 PM
  #21
keep_hope_alive's Avatar
Battery was fine, so we left it. A battery swap would be pretty easy. Getting to the digitizer connector in the back side of the board was a PITA
Old May 25, 2011 | 02:49 PM
  #22
SSharon's Avatar
I had a few minutes to kill during lunch today so I started taking apart the dash to see how hard it is. I removed everything I need to except the cubby and only dropped two metal clips into the well (which I recovered). I can tell that I will need a magnetic screwdriver to put everything back together, but I'm confident now that i can do the install on my own.
I wonder if I'll ever figure out where the metal clips came from so I can put them back in the right spots...
I hope the part is delivered early!
Old May 25, 2011 | 04:29 PM
  #23
The backside of the dash trim. You will see others on plastic tabs.
Old May 25, 2011 | 06:17 PM
  #24
SSharon's Avatar
Thanks, I found where they go. When I got home I was also able to remove the cubby area. The only thing left to do is figure out how to unplug the white cable. I didn't spend a lot of time looking at it and I wasn't sure how much force it needed or in which direction or if there are any release tabs.
I guess while I have everything open I should replace the light bulb for the passenger's heated seat which is burnt out.
Old May 25, 2011 | 07:01 PM
  #25
barticus520's Avatar
lol i gotta get the bulb for the drivers heated seat light, and trac control, and the moon roof.
Old May 25, 2011 | 07:09 PM
  #26
SSharon's Avatar
lol, our accords are pretty similar! Where are you going to buy the lights from? Is it something that autozone stocks or do we need to get it from a local honda dealer?
At least I don't have traction control so there is no light there to go out. I do have a moonroof, although I can't picture in my mind where there are any lights for it.
Old May 25, 2011 | 09:05 PM
  #27
hondapartsdeals dot com is where i get all my OEM parts. i just ordered new A-pillar garnish and it came in today!
Old May 25, 2011 | 09:43 PM
  #28
ill probly just go to honda since its like 2 min away n bulbs are really cheap anyways.
Old May 25, 2011 | 10:38 PM
  #29
SSharon's Avatar
I found some amazing instructions on how to install the bulbs over at an acura forum since they use the exact same part.
See:
Replacing the light bulb that lights up the heated seat button - Acura TSX Club : Acura TSX Forum
and
VSA/Moonroof/Seat Heater/Gear Shift Lights Replacement - Acura TSX Club : Acura TSX Forum
The second link has pictures, etc. Both threads also mention that if you don't mind cutting the extra wire, you can save a few bucks by getting the bulbs at radio shack instead of OEM.
Old May 28, 2011 | 09:14 PM
  #30
SSharon's Avatar
See:
and
Just to give an update to anyone reading this I got the bulbs from radio shack (they are in a baggie now instead of the box like they are in the pictures on the acura forum) and the replacement was pretty straightforward. I'll make sure they work tomorrow, but I don't see why they wouldn't.
