"New Guy"
Old Jul 22, 2010 | 10:37 PM
Keith McCavit's Avatar
Default "New Guy"
I own a 2010 LX-S Accord Coupe. I would like to install a small powered subwoofer under the passenger seat but I am a novice at car stereo installation. My first Accord was an 1983 Accord DX hatchback. It was a little easier to do installations back then. Can you tell me if I can get the power wire through the fire wall with out taking the dash appart and if I can where the location would be?
Old Jul 23, 2010 | 01:02 AM
Default Hello There New Member
1st off, I'd like to welcome you to the forums...
Please make sure you post in the correct forums by reading
all the headers in the top of each forum, and the stickys also.
Thanks For Joining the HAF:
Old Jul 23, 2010 | 06:40 AM
keep_hope_alive's Avatar
good question. i haven't seen the firewall of the 2010. you'll need to remove the lower drivers's side dash panel simply to gain better access. you'll also need to look behind the factory sound attenuating layers to view the firewall. most cars have a location above the gas pedal. if the wire is 8awg you can usually just fit it in along with the factory wiring bundle that comes through the firewall.
there are several small, thin subs designed for under-seat installation. you'll need a line output converter (LOC) with a remote turn-on, or a LOC and a sub/amp combo that has an auto-on feature. PAC-audio and USAspec offer oem integration pieces that simplify wiring with matching harnesses, and give you RCA outputs.
Frankenstein94
Oct 29, 2014 01:02 AM
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
