Radio 2003 Honda Accord EXEX
Old Sep 9, 2004 | 09:41 PM
Jeff247's Avatar
Default Radio 2003 Honda Accord EXEX
My radio, CD changer and clock work, but I can BARELY see the numbers on the panel. Nothing lights up. It's like the brightness is turned down all the way. Any suggestions? Thank you
Jeff
Old Sep 9, 2004 | 10:54 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Sep 10, 2004 | 08:45 AM
Jeff247's Avatar
Default RE: Radio 2003 Honda Accord EXEX
Turn up interior dimmer!!!! Dam, why didn't I think of that. I knew you were a bright guy when you asked me if I wanted my lunch "supersized"!!!! I'll let you know if it worked!!!!
Old Nov 19, 2004 | 11:14 PM
poff1986's Avatar
all i can say is either check the fusebox for a blown fuse or maybe ur bulb burnt out..if not good luck!
Old Nov 23, 2004 | 04:10 AM
Yo Jeff did you ever check out your switch like some one suggested to see if that was your problem..Just curious!
Later
[IMG]local://upfiles/22/F40FB5B214B34029B4E67F41135886E6.gif[/IMG]
Old Nov 23, 2004 | 01:05 PM
poff1986's Avatar
yea wheels' rite..check so see if your dimmer swich could have lost its contacts...could be what the problem is...have had numerous hondas come in with that problem! just didnt think of it at the time....wtg wheel!
Old Jan 28, 2005 | 03:44 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Mar 14, 2005 | 12:59 AM
jagz_accord
guys
it also could be the front display cover. it might loosen up and dust could'v dimmed the display.
Old Mar 16, 2005 | 07:33 PM
2000Ex's Avatar
Or if You go to fix it color your bulb with a sharpie repeatedly like someone on the hcf said and you will have a tight looking light. Make it like green or blue. IT willl be the ish.
Old Nov 22, 2005 | 01:33 AM
Renee
I have the same problem as the rest of you I am going to call American Honda as some one recommended. This is very upsetting because I HAVE ALWAYS OWNED HONDAS AND THIS TYPE OF THING HAS NEVER HAPPENED. Between this and the scare of the transmission recall I will think twice in buying another Honda. Does any one have a copy of the SERVICE BULLETIN FOR THIS PROBLEM?
