Rear Speaker Grille Rattling
Old Jan 27, 2012 | 02:14 PM
rayo725's Avatar
Default Rear Speaker Grille Rattling
My speaker on the driver side behind the rear seats is rattling. How do I fix this? It stops when I put my hand on it
Old Jan 27, 2012 | 03:10 PM
crispin's Avatar
what year car?
you should put it in your sig
I believe you were the guy looking for exhaust for a 2003 (could be wrong here)
Fixing that rattle the right way is a lot of work
The speaker grill is attached to the package tray.
The package tray is attached to the rear deck with a bunch of tension pins (not sure of correct name) anyway removing the package tray will most likely cause many of them to tear out from the cardboard tray. - which sucks
Anyway the short easy method is to wedge something between the speaker grill base and the package tray. Fold of some thin stiff cardboard (like a playing card) and wedge that in there and see if that does the trick (it will) cause the other method is way too much work.
Old Jan 28, 2012 | 11:19 AM
keep_hope_alive's Avatar
Without knowing the year we cant give specific advise.
But I use foam weatherstripping to eliminate rattles, but it between the two hard surfaces.
Old Jan 28, 2012 | 11:33 AM
rayo725's Avatar
It's a 2003 lx
Old Jan 31, 2012 | 09:01 PM
have you removed the grills to verify? sometimes the third brake light rattles against the glass. i wedge some foam in there. foam is your friend.
Old Jan 31, 2012 | 09:29 PM
crispin's Avatar
Yea i got some large washers and put them between the nuts and under the rear deck so I could tighten the 3rd Brake light down much tighter than the way the factory setup was.
pro68camaro
Dec 28, 2008 02:18 PM
HORSEPOWERJUNKIE2007
Apr 16, 2008 07:26 PM
misscedes
Mar 25, 2008 04:36 PM
Namedname
Jan 26, 2008 01:22 AM
dknight211
Oct 6, 2007 12:52 AM
