sub question
Old Jul 24, 2008 | 02:54 AM
logan's Avatar
Default RE: sub question
that doesnt make sense tho my subs are 1000w rms together and my amp is suppose to push that much rms
Old Jul 24, 2008 | 05:50 AM
slammed97's Avatar
I'm still wondering what kind of load you're presenting to the amp. I ran a sony explode amp in one of my systems pushing fosgate 12's with a 2ohm load and it caused the amp to overheat. After doing that for a moderate period of time my explod eventially exploded. 1 month out of warranty of course.
Old Jul 24, 2008 | 05:59 AM
importedminds's Avatar
pham- if your head unit is shutting down from bass, you need to check your battery or alternator, i bet your battery is on it's last leg, just b/c it starts the car doesn't mean it is not bad, i had the same exact problem, new battery=no more problem for me
Old Jul 25, 2008 | 01:08 AM
logan's Avatar
i want to say 4 ohm cuz im running my amp to a sub and then from that sub to the other sub
Old Jul 25, 2008 | 05:33 AM
slammed97's Avatar
Are your subs 8ohm or 4ohm? Are they wired in parellel or series?
Old Jul 25, 2008 | 10:25 AM
pham9006's Avatar
i went to autozone and they told me my battery is fine. They tested it. And my capacitor shows voltage of 13.1 when its knocking. Lowest it goes is 12.1
Old Jul 26, 2008 | 03:32 PM
  #17
logan's Avatar
2 ohm parallel circuit
Old Jul 26, 2008 | 04:07 PM
  #18
slammed97's Avatar
as in each speaker is 2ohm and you have them wired parellel or you have 4ohm speakers wired in parallel giving you a final 2ohm load?
Old Jul 27, 2008 | 11:26 AM
  #19
i think he is getting a two ohm load after wired,
pham- weird, hmmmm, not sure what to make of that, usually if radio ****s down it's a lack of power from batt or alternator
Old Jul 27, 2008 | 04:07 PM
  #20
logan's Avatar
4 ohm subs wired parallel final 2 ohm load
