wiring 2 dual voice subs with enclosure
Old Sep 24, 2009 | 09:00 AM
My03Accord's Avatar
stripping the wire in then soldering in place is what i was talking about. "quick snap wire splice" or "t-tap" is a no no.
Old Sep 24, 2009 | 11:20 AM
toxiew
go to walmart they have a line to rca converter, you need to have it hooked up with rca's,
Old Sep 25, 2009 | 09:16 AM
My03Accord's Avatar
Already established the line-out converter, if you read more.
Old Oct 13, 2009 | 02:09 PM
Linda_kl
Default wiring 2 dual voice subs with enclosure
usually the wiring for the speakers to the amp wont make too much of a difference.. but its usually good to have like 12 or 14 gauge wire..
also,.. if you drop the ohms down to 2,.. make sure that your subs arent getting too much power.. b/c a lot of the time the subs will be labeled like 500watts or whatever.. but thats only their MAX wattage.. and their RMS wattage may only be like 150.. so just check to make sure that the rms wattage from the amp will not be too high when you drop down to 2 ohms b/c that is an easy way to blow a subwoofer
TooSlow
Mar 3, 2011 07:32 AM
Nightbreeze
Dec 7, 2009 12:44 AM
willowtreexx
11
Dec 17, 2008 07:54 PM
dlr213
Nov 15, 2008 11:53 AM
Will2Spill
May 16, 2008 07:38 PM
