Yellowtop diffrent kinds?
Old Nov 5, 2007 | 05:05 PM
tru_44's Avatar
Default RE: Yellowtop diffrent kinds?
ORIGINAL: MacLeod
The Yellow Top is a deep cycle battery which means you can run it down to almost dead and when you crank the engine up itll recharge to full capacity.
With a normal battery, if you run it down and then recharge it, it will not have the capacity it did before.
So the Yellow Top is perfect for using stuff with the engine off.
i just wanted to add that there are more then 1 type of yellow top optima batt. also there has been cases of optimas not taking a charge when drained a few times. so take that into consideration
Old Nov 5, 2007 | 06:29 PM
MacLeod's Avatar
There are different sizes of Yellow Tops, but theyre the same type.
The Yellow Top is the deep cycle battery while the Red Top is a starter battery. They also have a marine battery.
JOE.G
Jun 12, 2013 10:02 AM
ijryan3
Oct 22, 2011 08:50 AM
Miran
May 15, 2009 10:04 AM
clean coupe
Oct 9, 2008 06:08 PM
