Bird droppings, how often to remove?
Old Aug 31, 2008 | 10:52 PM
crvone's Avatar
Default Bird droppings, how often to remove?
Hi,
I park my car outside and every day find a couple of bird drppings on it . I usually clean upthe droppings as soon as I see them, but just wondering how bad is the stuff.
I do wax my car twice a year (have been using Banana Wax Laterly), and wash the car every 2 weeks using Meguierres Gold Classic. Do you think this is enough to protect against the droppings if I were tolet them sit on the car in between washes?
Old Aug 31, 2008 | 11:40 PM
Default RE: Bird droppings, how often to remove?
i wouldnt let them sit on there, if you do for 2 weeks they will cook on with the sun and stuff and just generally not be good
Old Sep 1, 2008 | 08:49 AM
RTexasF's Avatar
Super Member
Do not let them sit at all because they are acidic and will etch the clearcoat. Use some type of spray detailer to wipe them off, never a dry towel. Wax (with the exception of the Collinite brand) is good for 4-6 weeks MAX so @ twice a year you're not doing a lot to help the situation. Either wax monthly or switch over to a good sealant which will generally last 4-6 months depending on weather conditions.
Old Sep 2, 2008 | 07:41 AM
08coupex's Avatar
ORIGINAL: RTexasF
I couldntsay it any better. Im picking up Collinite 845 in the next 2 weeks.
Old Sep 2, 2008 | 11:44 AM
05Tamcoupe
Just carry some Quick Detailer or similar and remove right away. It will etch into the paint before you know it and then you'll be using elbow and scratch-x to try and get it out. Same with lovebugs or any type of bug. Too much acid in the matter and it will eat though the coats of paint all the way to the base, but will be as visible as being up top.
Old Sep 12, 2008 | 06:03 PM
crvone's Avatar
Thank you for your responses. I now carry a damp towel and a B.B. gun when I go out to the car!!
Old Sep 14, 2008 | 04:47 PM
YoungLemon's Avatar
remove asap, it is very acidic and can mess up ur clear coat and work its way down to the paint.
daftshadow
Aug 26, 2013 01:14 AM
dunnskii
Jan 27, 2011 01:42 PM
RTexasF
Dec 2, 2006 04:33 PM
dmolina
Oct 3, 2006 12:52 PM
