DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
Auto tranny fluid change method
Old Jun 5, 2010 | 03:36 PM
Kazoo2U's Avatar
Default Auto tranny fluid change method
While new to this forum, have been a member of the CR-V forum for a while. With regards ATF changes, a member of the CR-V forum came up with this method of changing ATF: http://www.crvownersclub.com/forums/...?t=2324&page=2, especially entry #16. I plan on doing this with the CR-V & Accord at every 2nd oil change, or approx. 7.5K using Honda ATF. Will buy 4 qts Honda ATF @ dealership.
Still do my own wrenching. Have used synthetic motor oil for over 20+ yrs, won't go back to dino. '93 Accord had balance shaft seal blow @ 60 mph, dumping out all oil within 20 seconds. Shaft seal replaced & refilled with synthetic, then drove for another 45K w/o using any oil.
Change oil, oil filter, & air filter acc. to MM @ around 7.5-8.0K. Cheap insurance, plus it gives me something to do. Have heard too many horror stories about the corner 15-minute oil change places to let them do it. I do take my old oil to them for recycling, though.
Old Jun 6, 2010 | 10:06 PM
YES, I like his idea to reach an ATF change interval (like say 15k) where the oil never gets so dirty that you need to do multiple drain/fill cycles.
Actually, what I like even better is a car with three pedals on the floor. That way you can drain nearly all the fluid.
Old Jun 24, 2012 | 03:12 AM
Silver6gen's Avatar
So on another note about the transmission....
I have an after market cooler that I added inline with the stock transmission cooler for my car. It helped my automatic go through 145,000 miles (30k with a turbo and 230whp) until my transmission finally chewed the case up and stopped engaging 1st gear.
So I had the transmission rebuilt by a friend. I am 15,000 into the new trans and things are going well. I've done two fluid changes ( 8000 and 15,000) and saw that the magnetic plug had collected quite a bit and the fluid wasn't as fresh as I would have hoped (since I did the change early I expected it to still be a cherry red, but it was more like licorice.
Anyway, would it be benificial to install an inline filter next to my transmission cooler? I know my 2002 Accord doesnt have an external filter.... So what are your thoughts?
62maxx
Oct 18, 2015 08:20 AM
93Accord2.2
Jan 20, 2012 01:02 PM
louisssss
Jun 16, 2009 08:34 AM
19Accord97
Jun 16, 2008 11:10 PM
accordfan
Aug 2, 2007 05:43 PM
