DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
Check Engine Light won't come on
Old May 3, 2010 | 03:37 PM
rozek's Avatar
Unhappy Check Engine Light won't come on
My '90 Honda Accord EX wont start. I have replaced the master relay, and a rebuilt distributor, the engine cranks but won't start. The "check engine light" does not come on at all when the ignition is switched on. There is no problem with fuel, the spark is not bright blue/white but yellowish and weak. The battery is brand new. Can someone please help especially with CEL that won't come on. Thanks.
Old May 3, 2010 | 04:17 PM
deserthonda's Avatar
Old May 4, 2010 | 07:43 AM
I only skimmed that real quick, but I didn't see a check for the bulb being burned-out??
Check the simple stuff first.
Old May 18, 2010 | 11:44 AM
hondAddict's Avatar
If the "Check engine" light does not come with the ignition ON, it's possible that there is no power coming to the engine computer (e.g, due to a broken wire, faulty relay, burnt fuse, etc.) or that there is a problem with the engine computer itself.
Sometimes a car may have an intermittent problem, when it starts fine most of the time, but once in a while it doesn't. Such problems, that are not presented at all times, could be very difficult to diagnose. What will help your mechanic to find such an intermittent problem is if you notice when, under what conditions the car doesn't start and what helps to get it started. For example, if you notice that wiggling the ignition key helps to get the car started, it may tell your mechanic that the problem is likely with the ignition switch (very common problem). Or if the security light flashes on the instrument panel each time the car doesn't start could tell your mechanic to begin with checking anti-theft system.
Old May 18, 2010 | 01:15 PM
If it was just a burnt bulb the car should start ,,,,,,,,,,,,,,He also has a no start condition
Old May 18, 2010 | 03:51 PM
If there was no power coming to the ECU, there would be no spark whatsoever. He says there's a weak spark.
If he has had a burned-out bulb for a long time (not noticed) then maybe NOW it's trying to throw a CEL code but it can't.
Paullad
Aug 20, 2013 08:36 AM
mamtsberg
Nov 29, 2010 05:35 AM
ricky80
Aug 17, 2010 10:49 PM
AccordNation
Oct 15, 2009 11:15 PM
nrangerfan
May 20, 2005 01:57 AM
