Check engine light come on
Old Aug 17, 2010 | 10:04 PM
ricky80's Avatar
Default Check engine light come on
hello, I have a honda accord 97 V6, 3 month ago check engine light come on, I took to autozone they pluged to the computer wich show code p305
misfire on cilynder 5, I replaced the spark plugs, new spark plugs wires from the dealer, replaced rotor, rotor cap, check the gasoline injector 5, clean EGR valve and EGR valve passage or pipe, I reset the computer, run the car for about an hour and the check engine light come on again, and I smell gas close to the EGR valve wich I believe I need a new EGR gasket
I don't know were to start right now because the same code reading is showing again.
someone please help me.
Thanks.
Ricky80
Old Aug 17, 2010 | 10:49 PM
If you smell gas, it could be possible that you have an injector problem. It could be as simple as a bad seal.
When the engine is cold, turn the key to the II position, but do not try to start the car. After all the clicks from under the dash stop, turn the key off, and repeat a few more times. Run a paper towel around the two parts of the injector where it seats in the cylinder head and the fuel rail to see if there is any gas leaking out.
Try swapping the injector on cylinder 5 with another cylinder and see if you get a different misfire code on the new cylinder.
sweet
Nov 3, 2011 10:14 PM
mamtsberg
Nov 29, 2010 05:35 AM
rozek
DIY Answers.
May 18, 2010 03:51 PM
nrangerfan
May 20, 2005 01:57 AM
