DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
How to BLEED ABS Systems
Old Mar 8, 2010 | 03:45 PM
Post How to BLEED ABS Systems
This assumes you already know how to bleed the main brakes. Search a post by DesertHonda for those instructions.
Beginning in 1998, Accord ABS no longer has a separate fluid reservoir, and no longer has a separate bleeding sequence. Bleeding the main brake system pushes fluid through the newer ABS system and no additional bleeding is required. Bleeding order for the newer cars is LF-RF-RR-LR.
Bleeding ABS on Accord up through 1997.
The ABS modulator is shown. The rubber cap for the reservoir is #14, but also remove the other parts which have a tiny vent hole so you can pour fluid into the reservoir.
Check for leaks anywhere, but there's O-rings at the base of the accumulator (#23) and at the pump (#24). Fix any leaks first, & bleed the ABS after they're fixed.
The rubber cap for the ABS bleed screw is #1, while the bleeder itself isn't given a tag. Find a hose that fits well on the bleeder, & keep it under control while bleeding. Open the bleeder slowly, only just far enough to begin flow. There's enough pressure to cut through your skin if you're not careful.
1) After running the car, turn it off & fill the ABS reservoir to the MAX mark.
2) Open the bleeder carefully; turn it off immediately when fluid stops flowing.
3) Run the engine for a few seconds; turn if off after the ABS pump stops running.
4) Refil the ABS reservoir to the MAX mark.
5) REPEAT steps 2-4 several times until there's no more air bubbles coming out.
6) Replace all the caps & lids.
Last edited by JimBlake; Oct 13, 2011 at 09:18 PM. Reason: incorrect bleeding order
JimBlake
Mar 12, 2023 03:39 PM
sippy2
Jun 5, 2012 02:01 PM
leg_of_tape
Nov 29, 2006 03:38 AM
legionofone
Apr 27, 2006 07:54 PM
HondaLawgik
Jan 31, 2006 09:09 AM
