DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
Request For 94-97 Steering Wheel Removal/|Answered
Old Jul 8, 2010 | 02:58 PM
daddy's Avatar
Default Request For 94-97 Steering Wheel Removal/|Answered
Hi guys!
This request is for a tutorial on removing a steering wheel properly and safely from a 94-97 Accord. Also include how to remove and replace the switches (turn signals and wipers) as well. This would be a much appreciated tutorial.
Thank you
peace out,
daddy
Old Jul 8, 2010 | 04:26 PM
deserthonda's Avatar
Disconnect battery,, make sure to have the radio code if anti-theft radio
Remove air bag assembly as follows:
Remove mounting screw covers.
Remove mounting screws using T30 Torx bit. 1 on each side
Disconnect electrical connectors, then remove air bag assembly. When storing a removed air bag assembly, ensure pad is facing upward .\
Ensure steering wheel is in a straight ahead position, then remove steering shaft nut or bolt. i think that it is a 19 mm nut ,,
wheel might just come off if you pull up on it.,, if not,,, use steering wheel puller.Do not tap on wheel or steering column shaft when removing wheel .
the switches are pretty easy just remove the screws and unplug the electrical connectors
Old Jul 8, 2010 | 05:21 PM
Thumbs up There You Go Member
Desert is our resident tech who also owns one of the better Honda Shops in the country...
Attached Thumbnails Request For 94-97 Steering Wheel Removal/|Answered-112a61%7E118awesome.jpg
CACcord99
Apr 29, 2013 07:17 PM
neophyte
Feb 19, 2011 08:30 AM
88exi
Feb 7, 2009 12:37 PM
abelh7
Jul 28, 2006 04:01 PM
