Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
Brake light turns on when driving
Old Dec 2, 2007 | 07:25 PM
HondatechAV6's Avatar
Default RE: brake light turns on when driving
There is a 'problem' with the brake master cylinder float. It creates too good a seal causing a pressure difference. This causes the fluid level inside the filter to be lower than the fluid level outside the filter. Since the float is inside the filter, it sets off the brake warning light. Usually this only occurs after the car has been sitting for a few hours and goes away after driving 15min or so.
Replace the filter with the updated filter or modify your filter.
To modify: Cut two small notches 180 degrees from each other. The notches should be as big as the letter U i just typed. Use a pair of side cutters to do the dirty work. Make it look like the new style:
swall82
Apr 5, 2013 09:14 AM
victorywhity
Mar 24, 2011 09:37 PM
SpeaCKJ
Dec 21, 2008 02:43 PM
trunks932
Dec 2, 2007 07:25 PM
mknauff
Mar 20, 2007 09:20 PM
