1988 Honda Accord DX doesn't start
Old Apr 4, 2024 | 07:21 PM
nate73price's Avatar
Question 1988 Honda Accord DX doesn't start
I have been having this issue with my car for a month now. All electrical components turn on such as lights and radio. When I go to start my car, the starter motor cranks the engine however I don't get a strong enough spark to start combustion. I've replaced the Distributor, ICM, and the Ignition coil but nothing seems to solve the issue. We tested to see if we have anything coming out of the ignition coil by get a ground cable near the cable connection that goes to the distributor and we got a single weak spark when we initially start the car but nothing after constant cranking. Is there anything else that I should be looking at?
Old May 8, 2024 | 12:59 AM
SirGuote's Avatar
Hello,
I am just going to assume you also changed out the spark plugs as well or at least tested them somehow, and as always never forget to check the fuses/relays as its always a cheaper replacement. Another couple of things I would check (for free at AutoZone or O'Reilly's) is the battery and alternator. Make sure your battery has the right voltage for your car as well. Also keep in mind that it may be a fuel issue rather than a spark..
Theknifeguy100
Nov 21, 2022 08:29 AM
Jones Honda
Jul 17, 2019 07:57 AM
Thomas Hawkins
May 13, 2013 11:31 PM
jmaxim6
Nov 9, 2011 08:37 PM
russo_p
Apr 22, 2008 11:09 PM
