1994 Honda Accord LX VSS
Old Sep 17, 2007 | 05:41 PM
nrmskate's Avatar
Default 1994 Honda Accord LX VSS
Ok, So Ive takin both of the bolts out of the VSS like I was told to, this task Was incredibly hard, It took me an hour a bolt.
So after spending 2 hours on getting two bolts out, I cant get the electric unplugged from it or revome the VSS itself.
I can't get my hand down there to even touch it, there are so many things in the way, That arnt movable (Without a mechanic knowing what hes doin and the right tools)
Anyone have any ideas? I have just bought a new one and am trying to replace. But I can't even get the old one out.....
PLEASE HELP!
Nick
Old Sep 17, 2007 | 05:52 PM
sir_nasty's Avatar
Default RE: 1994 Honda Accord LX VSS
This is the first I've heard of having that many issues with it. I know the wire harness has a small item that has to be pushed in to release it but the sensor itself should just pop out/lift out. Have you tried to twist it at all?
Old Sep 17, 2007 | 06:38 PM
nrmskate's Avatar
I would try, But i cant get anythign down there to do that, the only thing i have is the twisty rench in which i got it off with.
I got so desperate as to where i got a fishing hook and tried to yank it out by attatching it to the wire, Still wont budge.
PLEASE HELP!!!!
Nick
Old Sep 17, 2007 | 06:52 PM
deserthonda's Avatar
Nick.. did you remove the throttle body air tube ?? if not remove it . it will give you a lot of room
did you remove the 2 , 10 mm bolts on top of the electrical part of the vss?? you need a 10mm socket and a long extension, it works real well., then unplug it and it should come right out . You need to get the proper tools to make the job easier ,,
But as Sir said,, it is a very, very easy job to do ,,
Old Sep 17, 2007 | 07:06 PM
nrmskate's Avatar
Thanks guys, Yeah, Im having troubles with the Air tube, Its difficult to get off, But i managed to fit my skinny arms down there and get the VSS removed.
Now my goal is to get the new one on, becuz now my arm is bleeding from sticking it down there.
Old Sep 18, 2007 | 11:02 AM
00AccordLX5spd's Avatar
Registered User
OMG man! Put a band-aid on that! Take of the throttle body air tube. It should only be atached by a ring clamp. If you can't get to the screw to loosent the ring clamp, go to AutoZone and buy a new clamp for like $0.50 and rip the old one off with a pair of pliers(but DON'T damage the tube)!
tampabayshore
Nov 10, 2023 12:39 PM
ceecee1968
Oct 14, 2009 05:25 PM
humblehyper
Nov 19, 2008 12:26 AM
comptoncarl
Feb 8, 2007 03:04 PM
cbriley3
Oct 23, 2005 11:04 PM
