2.3 enginge trouble
Old Oct 1, 2011 | 07:55 AM
beastro's Avatar
Exclamation 2.3 enginge trouble
Hello everyone, My engine is buring oil but not out the exhaust. I pulled the plugs there was no oil redisue but they were white from to much heat. I read these engines have a valve problem. can anyone give me more info on what ia actually happening in there? I am machanicly inclined just need to know about the honda engine. I have not done a tune up yet because I just got the car but befor I do i want to fix the oil problem first. so any info or insite on to what is going on would be great thanks.
Old Oct 1, 2011 | 08:07 AM
Depending on how much oil is being consumed, it may not show up on the plugs.
Things to check:
1) PCV system can pull oil into the intake if the PCV valve or hose is blocked.
2) Valve stem seals can leak. I had this on a Mitsubishi V6 and symptoms were only, oil consumption 1qt/500 miles, puffing oil smoke when engine was fully warmed and a prolonged idle, a burst of oil smoke after an idle at a stop light.
Old Oct 2, 2011 | 08:57 AM
beastro's Avatar
When I was running 5w30 that it recommends I was burning 2 quarts every 3 days my last oil change I put in 10w30 and I have lost 1 quart in 5 days. So its not to bad now. I have a new pcv valve to put in and then will clean out the egr valve and idler valve is there anything els I should clean out the engine has 90k on it. I get no puffs of smoke when I start or when driving. Thanks for the help
Chomp
Feb 6, 2006 07:48 PM
cloob
Oct 25, 2005 09:55 PM
95EXV6
Jun 27, 2005 08:21 PM
accordian
Jun 6, 2005 12:03 AM
Getsch
May 24, 2005 07:52 PM
