2004 accord 2.4L auto 200k+ miles It appears my crank position sensor on the timing
Old Apr 18, 2021 | 11:43 AM
j894's Avatar
Default 2004 accord 2.4L auto 200k+ miles It appears my crank position sensor on the timing
200k+ miles
It appears my crank position sensor on the timing cover is leaking and I'm willing to bet the leak is due to a dried out squared off o-ring on the base of the sensor shaft, given the age and mileage. I wanted to just replace the o-ring (91333-PNC-006) first to see if that stops the leak or if there's another problem with the sensor.
I understand if replacing the crank sensor with a new unit that there is a relearn procedure that must be done, however would this be needed just for removing the existing sensor, installing a new o-ring on the end and putting it back in? I wouldn't think so but wanted to see if anyone has actual experience doing this before opening a can of worms.
If the relearn procedure is need, is there some kind of DYI method that doesn't require a Honda scan tool? The information on this is very murky. Or are there any $100-200 scan tools that do this type of relearn on hondas? I'd rather spend a little more money and have the tool than paying a dealer to just do the relearn for an exorbitant price, one time.
myAccord03
Feb 28, 2018 07:40 AM
welchineer
Nov 21, 2017 11:05 PM
3dw1n
Jan 14, 2015 01:53 AM
rahulvasudeva
Sep 14, 2009 10:38 AM
SuperGeeky
Jun 26, 2009 05:55 PM
