2006 V6 Accord Manual Tranny Clutch Problem
Old Nov 17, 2016 | 10:34 PM
cpo1's Avatar
Default 2006 V6 Accord Manual Tranny Clutch Problem
Recently replaced the master and slave cylinder, but still have an issue. When sitting for a few minutes with the engine running, at times I cannot shift into gear. Shutting the engine off allows me to shift and then I can start in gear and move on. But the clutch pedal pressure is always affected when this occurs. Barely releasing the clutch causes the car to start moving. After driving for a few seconds and going through the gears, everything seems to get back to normal. I had a garage look at the master cylinder to make sure it was bled properly and they said it was. I'm still skeptical about that, but at any rate, I still have a problem. This issue can also be exposed when driving hard through the gears on takeoff. But backing off and driving normally seems to bring everything back into an acceptable and seeming normal mode, pedal pressure, play, and all. Any suggestions? Thanks
Old Nov 18, 2016 | 10:20 AM
Worn or damaged clutch pressure plate can cause these symptoms.
First check that slave cylinder is fully extending when clutch is depressed. If not there is a problem w/ slave or master cylinders.
If slave extends fully w/ depressed clutch a damaged pressure plate is likely.
Old Nov 18, 2016 | 04:10 PM
cpo1's Avatar
Thanks TexasHonda. That gives me a good starting point. I appreciate your help.
Budfraze
Mar 21, 2011 07:55 PM
littleolme
Mar 19, 2010 06:47 AM
ZMan3000
May 11, 2008 07:56 PM
finch13
Apr 1, 2008 09:21 AM
tamb
Jul 21, 2006 01:05 AM
