2010 Accord V6 Engine Loud Tapping Noise
Old Apr 17, 2010 | 05:09 PM
brucehjr's Avatar
Default 2010 Accord V6 Engine Loud Tapping Noise
At 2,000 miles I took the car into the dealer to investigate what i would describe as a loud valve tapping noise. They said a TSB was out to repair a similar noise but my VIN was not covered. They received authoriation from Honda to investigate and they performed a valve adjustment. At least they say they did. The noise is not any better and I think it is getting worse. Any ideas or recommendations?
Old Apr 18, 2010 | 07:01 PM
SnaveZ's Avatar
well you can go one of two ways...
one: you can bring the vehicle to another dealer. You're vechicle is covered by honda for 3 year 36k powertrain warranty. By going to another dealer you can have them investigate the problem and see what they find.
two: since all new Honda's have the 3 year 36k you could just drive the car until something goes and then Honda will replace the parts that are broken.
This might help you out...I work for a Honda dealer in AZ. We had a customer with the same complaint come in. They had a Honda Ridgeline with 1500 miles on it. The Ridgelines have the 3.5L V6 VTEC...same as the accords... What happened to their Ridgeline was the cylinder wall on cylinder 6 had actually gotten so hot that it started to fold over the top of the piston. So whenever the piston was on the up stroke it was making a clanking/tapping sound. HoA (Honda of America) funded the replacement for a new motor along with a new head (because the head actually suffered some damage too)
A Valve adjustment should have eliminated the noise unless the technician did the valve adjustment incorrectly.
One other thing it could be....is not enough oil. Honda has a tendency to ship cars from the factory with just enough oil to start the motor (to see if they run). Usually it's not enough oil for the motor. I see this a lot when I have a Honda to PDI. Check the oil level make sure you're good.
Now if you have the 4 cylinder...sometimes these make just a little noise. I guess it's typical cause I see Honda Accord 4 cyls that make just a little tapping noise.
Hope this helps you out!
SnaveZ
kwakers
Aug 16, 2015 01:18 PM
faran
Dec 18, 2013 08:13 PM
Derekhhh
Oct 13, 2013 03:14 PM
ekgandj
Jun 5, 2012 11:38 PM
lotas
May 8, 2012 08:50 PM
