5W-20 oil for '00 Accord LX?
Old Aug 31, 2007 | 02:13 PM
Hen_Rock
Default 5W-20 oil for '00 Accord LX?
I just recently moved from Virginia to Louisiana. I have a 2000 Honda Accord LX, 4 cylinder. The Hondadealer servicein VA always put 5W-30 oilin my engine. The dealer down here said they put 5W-20 oil in Honda. Is this because of the climate difference? I'm just wondering if this is a good idea.
Old Aug 31, 2007 | 02:50 PM
RTexasF's Avatar
Super Member
Default RE: 5W-20 oil for '00 Accord LX?
Honda recommended 5W20 be retrofitted for certain models/years. Find out if yours is one of them. If so you're good, if not go back to 5W30.
Old Aug 31, 2007 | 03:20 PM
00AccordLX5spd's Avatar
Registered User
I use 10W30 on my 2000 Accord LX in Mississippi.
Old Aug 31, 2007 | 07:00 PM
Chiovnidca's Avatar
Honda changed there recommendation a few years ago. 5w20 for 98- 02 accord
Old Sep 4, 2007 | 03:08 PM
falkore24's Avatar
00Accord: The first number doesn't make much of a difference when running. It indicates what temp the oil will get thicker and make it harder to start. I'm not sure of how the 5 or 10 relates to the real world temp, but a 5 will start easier in the winter than a 10. The second # is the weight of the oil. If you shake a bottle of 5w30 in one hand and a 5w20 in the other, you will notice that the 20 weight is much thinner oil. My car doesn't like 30 weight oil. It makes the engine a bit louder and on a few civics, I've heard of the heavier oil causing a sewing machine noise from the valves that goes away with the proper oil.
Old Sep 5, 2007 | 12:30 PM
Alekat's Avatar
Go with the owners manual
Its all about bearing cushion.
Believe it or not.
Old Sep 6, 2007 | 10:15 AM
Registered User
The manual says 5w30 or 10w30. 10w30 was for hotter climate. I was not aware Honda changed their recommendation to 5w20 though.
I knew thatabout the numbers, I just didn't mention it. I used to run 40 weight in my 5.0 mustang. I wouldstill be nervous that 5w20 would be too thin, but I am no oil pro.
Old Sep 6, 2007 | 11:03 AM
falkore24's Avatar
I'm not doubting you 00. I thought that the # info could help some other readers and maybe the thread originator. Non gearheads typically won't know this and just know that 5 or 10w30 is the one that they hear about most.
Old Sep 6, 2007 | 11:18 AM
Registered User
Oh, I know. Good point. Someone did need to post that info.
11_22_1992
Jun 19, 2015 12:20 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
jasonan
Aug 28, 2009 11:26 PM
thunder_x
Oct 22, 2006 09:56 AM
nygamble
Jun 11, 2006 07:13 PM
