700 HP: Truth, False, or Possible?
Old Jun 5, 2007 | 03:30 PM
19Accord97
Default RE: 700 HP: Truth, False, or Possible?
ORIGINAL: smaglik
I put the tornado intake thing on my m3 and now it pushes over 1000rwhp.
How the heck did I forget those existed?! I just bought 3 of them, so ill gain another 2700hp putting me at 3200ish hp and my mpg will triple. Yesssss
Old Jun 6, 2007 | 06:49 AM
YeuEmMaiMai's Avatar
hp generally speaking (ideal world) is dependant upon the following
1. engine displacement
2. engine speed
assuming that an engine has unrestricted airflow into cylanders, (IE it can get all the air it needs at any RPM) then as your engine speed increases so would yourtorque and HP (a function of torque) or as you increased your displacement your HP would increase linerally
Obviously there is more to it such as intake design,# of cylanders, compression ratio, fuel used, etc but I would find it extremely hard to believe that a 2.2L engine (no matter how well it is designed) can produce over 318hp/litre.....naturally asperated.
Honda does well with the S2K motor at just over 120hp/litre (origianl was 2L) but you had to spin that sucker up to 8300rpm to get it
Old Jun 6, 2007 | 07:42 AM
RTexasF's Avatar
Super Member
ORIGINAL: legionofone
hell the biggest NA K series i have ever seen was 325 and thats a far better engine then the H or the F Fseries are capable of 500-800 MABY if they are turbo and built right
He's talking 700 HP NORMALLY ASPIRATED not turbo'd or supercharged. No way.
Old Jun 6, 2007 | 09:38 AM
marbro's Avatar
ORIGINAL: 19Accord97
ORIGINAL: smaglik
Pimpin! but you need to get the turbonator ultra lights, they are 50% lighter then the regular and they even reduce your cars weight by 275lbs for each one you add!!!! You too can reap this benifit through use of intravenous drug use! ^_^
Like everyone has said, not possible without a turbo
Old Jun 6, 2007 | 02:17 PM
legionofone's Avatar
ORIGINAL: RTexasF
yeh... and... i was saying that turbo 700 would be a stretch...
Old Jun 6, 2007 | 08:37 PM
KevinAccord's Avatar
this is really stupid.... if that could be possible everyone would want a F22 accord... starting by me!!!!!! not even skylines not suprs go that far w/out turbo!!!! though ur friend is either a liar or a fool to believe that.... does anyone has swapped a H22 into their accords? i need some info on that!
Old Jun 9, 2007 | 04:19 PM
  #17
03Sleeper's Avatar
The sarcasm is so thick in this thread you can cut it with a knife.
NAH MAN...MY VTEC STICKER...INSTANT 500 HP BOOST AT ANYTIME DUDESSS
Old Jun 10, 2007 | 09:19 AM
  #18
pyaarawala's Avatar
What the hell? Adding an H22 HEAD will give you 400hp or completely swapping out the engine head & block with an H22 will give you 400 hp? How does that even give you 400hp?
Old Jun 10, 2007 | 11:16 AM
  #19
marbro's Avatar
ORIGINAL: pyaarawala
ok, where did you get that from?
Old Jun 10, 2007 | 12:54 PM
  #20
I think he's adding to the sarcasm or just got a wrong thread.... anyhow, it's still a stupid thought
