700 HP: Truth, False, or Possible?
ORIGINAL: marbro
Actually the real way to win the race is tune your car, set the timing 180 degrees off, they "claim" it will damage your car, but i have found that the pistons impacting the valves produces an amazing gain. The force from the impact transfers back to the crank causing it to rotate even faster so you run through the rpms in about 1 second 4 second car baby!!
ORIGINAL: pyaarawala
You kidding? I've won countless races using the fastest method of all. Stick the car and neutral and have people push the car from behind. No pain no gain.
I have not yet begun to defile myself.... or this thread for that matter....
I was told the other day that Hydrogen is more flammable than gasoline so it only makes sense to drain your fuel tank and fill it with water!
ORIGINAL: sir_nasty
I have heard that but I thought that it didn't work unless you mixed sugar with the ram urine then you got the gains, otherwise the urine alone was like a turbonator effect, all sound no gains..... I think it's the chemical reaction of the ram urine, sugar and fuel mixture.....
ORIGINAL: marbro
not just any urine mind you, it has to be the urine of a ram, rams urine will libricate you engine while giving you 7000% hp increase
ORIGINAL: sir_nasty
Hey...DesertHonda my friend!!!
What do you think about this thread? I know your here reading it , so what's your opinion Sir
DesertHonda Guy
[IMG]local://upfiles/22/0D678B1221344690BC46554B0FAC9AB3.jpg[/IMG]
DesertHonda Guy
great thread!!! let's keep it alive!!!!
and, a question....Where do u get Chuck Norris Urine? we can find something to neutralize it's powerness and make it more agressive toward the strength of the engine.... oh, ebay is selling clean air in a tank, so it weights less. we should use it on our cars!
