90 Clutch Issue
Old May 8, 2006 | 12:36 PM
balismail
Default 90 Clutch Issue
I have a 1990 Accord LX and woke up this morning to find that my clutch wasn't releasing on my way to work. I only drove it about a block or so (because I felt like I was beating my car!). Any idea as to why it wouldn't release? Is it time to replace the clutch (seemed to be working fine up until this point)? Thanks for any help!
Old May 8, 2006 | 01:15 PM
sir_nasty's Avatar
Default RE: 90 Clutch Issue
I'm assuming by not releasing the clutch pedal wasn't coming back out? or is the clutch not being pulled off the pressure plate so you can't shift? Was it making any noises etc?
Old May 8, 2006 | 04:05 PM
balismail
Yes, that is correct. The clutch pedal was not coming back out with alot of pressure. It was coming out, but it felt much weaker than normal. I tried pushing in and releasing the pedal several times, but no luck.
No noises were made, just really really hard to get into gear.
Thanks for the help!
Old May 8, 2006 | 04:38 PM
sir_nasty's Avatar
It sounds to me like it's either an issue with your clutch cable or your return spring.... but if it's hard to get into gear then I'd be more prone to thinking it's a cable/tranny issue.... Have you checked your tranny fluid lately to make sure it's full and nothing is leaking, also trace your clutch cable to the top of your tranny and make sure the cable and everything looks fine...
Old May 8, 2006 | 10:06 PM
deserthonda's Avatar
ORIGINAL: sir_nasty
90 accord no cable, lat year cable was on a 89 ..
90 started with hydraulic system..
chk the easy things first, chk to make sure clutch master cylinder has planty of fluid,, possible air in the system if no fluid in reservoir either clutch master or slave master or hose leak,,
if it is the clutch master (most likely leak,)or slave master leak , let me know i will give you an how to step by step instructions
if no leaks than sir nasty is right possible pressure plate , clutch disc issues,,
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
w_nter
Mar 11, 2008 08:31 PM
tamb
Jul 21, 2006 01:05 AM
