91 Accord SE all brakes locked up
Old Jun 14, 2011 | 10:51 PM
mike adkins's Avatar
Default 91 Accord SE all brakes locked up
Here's one I cant find an answer on anywhere on the internet! I feel like I have the only car with this issue! I bought a cheap 91 accord se, all the brakes are locked up, they said it might be an anti lock issue somewhere. The pedal is totally stiff so I removed the master cylinder and alot of psi blew out ( just air, not fluid). Then the pedal moved again, so re-installed the master cylinder and the brake pedal moves now but the brakes are still locked up. Here is the weird thing ( I have the front end up on jack stands) I put the car in gear and just slightly put my foot on the brake pedal and the wheels move, but when I apply preasure or let off the pedal they lock up again!!
Any help anyone can give me will be very very much appreciated.
Old Jun 15, 2011 | 10:48 PM
Sounds like the pushrod is adjusted too long. When you replace master cylinder, there's a measurement & adjustment you have to make.
Old Jun 18, 2011 | 02:50 PM
Thanks for your reply! Would that happen to be the screw on the master cylinder that is located between the two line connections?
Old Jun 18, 2011 | 08:19 PM
You may have trash in the brake lines. Bleed all 4 wheels and be sure you have fluid everywhere.
If booster push rod is too long, it will not release the brakes and lockup will occur as fluid warms. Adjustment is a royal PIA. I bought OEM MC to avoid this problem.
Check Online Manuals links in DiY forum for a 1991 Accord download manual w/ pushrod adjustment procedure.
Old Jun 19, 2011 | 09:26 PM
That's NOT the screw on the master cylinder.
Pushrod adjustment is probably down under the dash - somewhere on the pushrod from the pedal into the firewall & booster.
I think it might be the nut #17 in this picture??
Old Jun 24, 2011 | 06:22 PM
Thanks for this great info!! I have not had the chance yet to try this, but I will give it a try hopefully this weekend.
Thanks again.
alphaney
Feb 12, 2022 10:14 AM
ghostman07
Jul 5, 2011 03:23 PM
bjr001
Jun 27, 2009 03:47 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
