92 Honda Accord wagon. Code 9 No.1 cylinder position sensor
Old Feb 26, 2019 | 10:40 AM
Seanjordan20's Avatar
What lines up? How did you check to make sure you were tdc
Old Feb 27, 2019 | 11:00 AM
Twinhonda92's Avatar
I had my distributor roter line up with the (a) mark by the first spark plugs wire and I looked down in the transmission to make sure I was line up with the white mark
Old Feb 27, 2019 | 11:39 AM
Did you make sure it was not on the exhaust side or try to turn the distributor 180 degrees to see if it would start
Old Feb 27, 2019 | 04:45 PM
Be careful just turning the distributor 180 degrees. The blade in the distributor shaft is off-center and is supposed to go into the camshaft only one way. But it IS possible to force it in when it's 180 degrees out. So just pay attention if it doesn't go right in.
pondrun
Nov 8, 2021 09:40 AM
bossie
Mar 29, 2021 11:17 PM
snubby bubkins
Jul 8, 2016 12:05 PM
c2m8c
Mar 28, 2012 09:57 AM
wiz929
Jul 23, 2011 06:27 PM
