93 accord idle speed is low
Old Nov 16, 2014 | 10:22 PM
erniep24's Avatar
Default 93 accord idle speed is low
Hey guys i have a 93 accord and i just had some work done to it i changed some bent valves and did the timing belt but even dough the car is doing great i noticed its vibrating alot when i stop at red lights and i know that my mounts are bad wich i will change soon but when the car is on park everythings perfect when is on drive and shaking the rpm is really low like 400 low and it turned off on me while waitting on a red light....i know i can adjust the idle speed but i need to know how to do it the right way...i know this will make it better becouse once before i got the last work done on the car i had the same issue everytime i turned on the a/c but went away once i turned it off ,and a friend (not sure how) made the idle speed a bit higher and kept the car from stalling when i had the a/c on and the rpms dropped
Old Nov 17, 2014 | 11:53 AM
Check out this thread.
https://www.hondaaccordforum.com/for...e-speed-38734/
First you get everything adjusted like it should be, as listed in that post.
Then the trick is to adjust the idle for 550rpm (feels way to slow) while the IACV is unplugged. When you plug it all back in & go through the "learning" in that post, then the idle should control OK.
But maybe there's some issue left over from the repair (like maybe a valve that you didn't replace but it's very slightly bent)? If so, you might not get the idle perfect until you fix that.
Old Nov 17, 2014 | 06:14 PM
Please be sure there are no vac leaks from the recent work. Also clean the IACV and TB before you start adjusting the idle. Again all other things need to be checked be just adjusting the idle.
Just me and my opinion....I have never had to adjust the idle on any Honda I have owned.
Old Nov 18, 2014 | 12:44 AM
erniep24's Avatar
Default thanks i
Ill give it a shot tmm and let u know
Old Dec 7, 2014 | 08:58 PM
fourcam's Avatar
sounds like your ignition timing is too far retarded.
irhunter
Mar 23, 2011 04:49 PM
96FiveSpeed
Feb 24, 2010 06:25 AM
ItsNewToMe
May 3, 2009 07:20 AM
Nitin
Apr 20, 2008 07:19 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
