94 accord with a 95 vtec swap no start issue
Old Jan 12, 2013 | 10:43 PM
carfreak4's Avatar
Exclamation 94 accord with a 95 vtec swap no start issue
Hi am new to this forum, i did look around to see if i could find the answer to my problem befor posting a new thread, but did not quit find anything the same. I had just bought a 94 non vtec auto accord with a 5 speed vtec swap. the f22b1 when i bought the car it would run and then die off right away, so i brought it home changed plugs, oil and cleaned a few things got it running kinda rough but it ran for a day now dead. it will start and idle for about 20 sec maybe about 1 min if i keep my foot on the gas then bam it dies off some times starts right up and dies agein some times it will crank but never start. here it what ive done so far fuel filter, new plugs, new altenator, new batterie termanals, o2 sensor (it was missing when bought), new injectors, cleaned egr ports, then after all that did fine and diesd off. so checked for spark found i wasent getting any from my coil so changed that and still nothing. im stumped ive tryed everything still no spark and i think that is my issue so can any one help? any advice would be a help im stuck right now. pleasee help?
thanks for reading,
Ryan
Old Jan 13, 2013 | 08:14 PM
go-part's Avatar
Former Sponsor
See if you get spark through the spark plugs.You could possibly have a bad ignition module,because your problem sounds electrical related.
Also have you replaced the distributor as a whole yet?
Old Jan 13, 2013 | 09:20 PM
carfreak4's Avatar
I have checked that as well and i dont have spark at he plugs or the ignition coil. so it has to be farther back in the system i would think im lost though
Old Jan 16, 2013 | 05:01 PM
carfreak4's Avatar
Just in case any one needs to know and is having the same issue, it was the ignightor that was the problem.
Old Jan 17, 2013 | 08:29 AM
THANK YOU! for coming back to tell us the fix. There's way too many threads where we never find out the end of the story.
cd51994accord
Jan 30, 2014 12:56 PM
kshellz
Oct 24, 2012 10:51 AM
Jojo97
Jun 29, 2011 06:48 PM
cg31998
Dec 15, 2010 10:29 AM
PTVDesign
Oct 28, 2008 09:20 PM
