94 Accord with f22b1 swap
Old Sep 17, 2014 | 08:38 PM
Jenna0416's Avatar
Default 94 Accord with f22b1 swap
I recently purchased my first Honda. Its a 94 coupe automatic.. It originally had a non vtech engine but the previous owner swapped it for an f22b1(I got it for a steal). It starts and runs, but idles around 2500 rpm.. When you loosen some tension on the throttle cable the Rpms will come down and idle just fine, until you put it in gear. It loses power and dies. I've gotten mixed answers.. Is it the wiring harness or the dizzy?
Old Sep 17, 2014 | 08:57 PM
Now you know why it was such a "steal".
Throttle cable should have just a bit of slack, 10-12 mm at the throttle linkage.
Idle Air Control Valve (IACV) may need to be removed and cleaned (intake screen, movement, and ports). Also clean throttle plate on both sides. Use throttle body cleaner.
Idle speed is managed by computer using IACV. You may need to adjust base idle by disconnecting IACV (check engine light will come on), and adjusting the air bleed screw (TDC of throttle body entrance) to achieve 550 +/- 50 rpms. Reconnect IACV and reset ECU by pulling BackUp fuse for 20 secs.
Old Sep 17, 2014 | 09:09 PM
Jenna0416's Avatar
Thank you for the advice. I'll definitely try those. I just couldn't pass it up.. The wheels and tires alone are worth what I paid for the whole car.. I considered it a plus it ran at all. I'll be even more impressed if it can be a daily driver with a simple fix.. But I'm not holding my breath
Old Mar 15, 2015 | 03:05 PM
sonice42's Avatar
Cool install f22b1 engine in honda accord ex 92
i have a cb7 92 and my engine is f22b doch non vtech and i find a f22b1 engine
its possible instaled with any problems
elmerochingon
Oct 25, 2012 10:21 PM
ShyTheBodyGuard
Sep 20, 2010 02:08 AM
swordfish7769
Jan 5, 2009 02:58 PM
mist3rm0
Oct 7, 2008 05:31 PM
xmasterx87
11
Jul 6, 2008 11:27 PM
